Salta al contenuto principale
Panasonic Lumix ZS50 Battery Replacement
Cosa ti serve
  1. Panasonic Lumix ZS50 Battery Replacement, Battery: passo 1, immagine 1 di 2 Panasonic Lumix ZS50 Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Turn the camera off and identify the battery door located on the bottom of the camera.
  2. Panasonic Lumix ZS50 Battery Replacement: passo 2, immagine 1 di 2 Panasonic Lumix ZS50 Battery Replacement: passo 2, immagine 2 di 2
    • Slide the "open" latch to the left: the battery door should spring open.
    • If your battery door doesn't open you may have to pry it open using a plastic opening tool or a standard spudger.
  3. Panasonic Lumix ZS50 Battery Replacement: passo 3, immagine 1 di 1
    • To release the battery, slide the white release lever next to the SD card slot.
    • If you find the battery release lever to be jammed you can push it using a plastic opening tool or standard spudger.
  4. Panasonic Lumix ZS50 Battery Replacement: passo 4, immagine 1 di 1
    • The battery should now be released; you may now remove the battery from the camera body.
Conclusione
Cameron Voos
Membro da: 02/01/17
32 Reputazione
1 Guida realizzata
Baylor, Team 8-5, Whitney Spring 2017 Membro di Baylor, Team 8-5, Whitney Spring 2017
BU-WHITNEY-S17S8G5
3 Membri
4 Guide realizzate
Un commento
Repair guide is very clear and well-done
BayleeVersteeg - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 15
Tutti i Tempi: 486
