Salta al contenuto principale
Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement
Cosa ti serve
  1. Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement, Mounting Bracket: passo 1, immagine 1 di 3 Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement, Mounting Bracket: passo 1, immagine 2 di 3 Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement, Mounting Bracket: passo 1, immagine 3 di 3
    • Remove the side panels by unscrewing the Phillips head screws on both sides of the camera.
  2. Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement: passo 2, immagine 1 di 3 Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement: passo 2, immagine 2 di 3 Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement: passo 2, immagine 3 di 3
    • Remove the back panel by unscrewing the two Phillips head screws on the bottom of the camera towards the back.
    • Lift the back panel from the camera and set it aside.
  3. Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement: passo 3, immagine 1 di 3 Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement: passo 3, immagine 2 di 3 Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement: passo 3, immagine 3 di 3
    • Unscrew the Phillips head screw shown in the picture to remove the front panel.
    • Remove the front panel to expose the bracket at the bottom of the camera.
  4. Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement: passo 4, immagine 1 di 3 Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement: passo 4, immagine 2 di 3 Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement: passo 4, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Pry the right side of the bracket up to allow you to grab the bracket with tweezers.
    • Grab the bracket with tweezers and slide it toward the battery door to remove it from the frame of the camera.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 325
