Introduzione
If your Panasonic Lumix DMC-ZS60 has been dropped and the lens is cracked, or you experience your lens jamming, you may need to replace your camera lens. Follow this guide in order to replace your camera lens.
A functional camera lens allows the user to use their camera to the full capabilities. Without the camera lens, no pictures can be taken and the camera becomes useless.
This guide requires careful handling of the inner parts of the camera, paying special attention to not disturb the camera sensor located inside of the camera lens.
Ensure your device is powered off before attempting to remove your camera lens.
Cosa ti serve
Use your finger to slide the black latch from the locked position to the open position on the memory card/battery door. This will open the door of the camera.
Using the Phillips #000 Screwdriver, unscrew six 3mm screws. There are two screws located on three sides excluding the top.
Unscrew the three 3mm screws attached to the plate cover using a Phillips #000 Screwdriver.
Pull off the plate cover to uncover the camera lens.
Un commento
A few years ago, I had a 30x zoom like this. It got a spot of dust inside the lens that showed up in photos, especially zoomed-in. I tried to unscrew the front of the lens to clean out the dust but the plastic broke, ruining the camera.
