Salta al contenuto principale
Panasonic Lumix DMC-ZS6 LCD Assembly Replacement
Cosa ti serve
  1. Panasonic Lumix DMC-ZS6 LCD Assembly Replacement, LCD Assembly: passo 1, immagine 1 di 1
    • Remove the battery and SD card.
  2. Panasonic Lumix DMC-ZS6 LCD Assembly Replacement: passo 2, immagine 1 di 3 Panasonic Lumix DMC-ZS6 LCD Assembly Replacement: passo 2, immagine 2 di 3 Panasonic Lumix DMC-ZS6 LCD Assembly Replacement: passo 2, immagine 3 di 3
    • Unscrew the two bottom 1.0 mm screws with a Phillips #000 screwdriver.
    • Unscrew the two 1.0 mm screws to the left with a Phillips #000 screwdriver.
    • Unscrew the two 1.0 mm screws to the right with a Phillips #000 screwdriver.
  3. Panasonic Lumix DMC-ZS6 LCD Assembly Replacement: passo 3, immagine 1 di 1
    • Separate the back of the camera from the main body carefully.
    • Do not apply excessive force. The LCD is connected by ribbon cables that can be easily damaged.
  4. Panasonic Lumix DMC-ZS6 LCD Assembly Replacement: passo 4, immagine 1 di 2 Panasonic Lumix DMC-ZS6 LCD Assembly Replacement: passo 4, immagine 2 di 2
    • Use the tip of the spudger to flip up the black tabs on the ribbon cables.
    • Pull gently on the ribbon cables to unseat them.
  5. Panasonic Lumix DMC-ZS6 LCD Assembly Replacement: passo 5, immagine 1 di 1
    • Use the tip of the spudger to flip up the metal tabs.
    • Lift the LCD panel out of place carefully.
Conclusione
Baylor, Team S2-G5, Johnson Spring 2018 Membro di Baylor, Team S2-G5, Johnson Spring 2018
BU-JOHNSON-S18S2G5
3 Membri
10 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 338
