Introduzione
If your Panasonic Lumix DMC-ZS35 camera’s won’t turn on, or if there’s another component of the camera that isn’t functioning as intended, it may be an issue with the Lumix motherboard. By following this guide, you’ll be able to remove and replace the motherboard to your Lumix.
Before you replace the motherboard, take a look at this Troubleshooting Guide to see if there is a simpler solution to your problem. Before beginning, make sure to turn off your camera completely and remove its battery.
Cosa ti serve
Remove the six 4mm screws located on the side and bottom of the camera casing using a Phillips #000 screwdriver.
Unscrew the four 3mm screws holding the LCD screen hinge in place using a Phillips #000 screwdriver.
Remove the four 2mm Phillips #000 screws on the sides of the exposed internal metal plate within the camera.
Using the opening tool, gently pry off the mother board. Run the opening tool along the outer edges of the motherboard as necessary to loosen it until it is fully removed.
