Salta al contenuto principale
Panasonic Lumix DMC-ZS35 Back Casing Replacement
Cosa ti serve
  1. Panasonic Lumix DMC-ZS35 Back Casing Replacement, Back Casing: passo 1, immagine 1 di 3 Panasonic Lumix DMC-ZS35 Back Casing Replacement, Back Casing: passo 1, immagine 2 di 3 Panasonic Lumix DMC-ZS35 Back Casing Replacement, Back Casing: passo 1, immagine 3 di 3
    • Remove the six 4mm screws located on the side and bottom of the camera casing using a Phillips #000 screwdriver.
  2. Panasonic Lumix DMC-ZS35 Back Casing Replacement: passo 2, immagine 1 di 2 Panasonic Lumix DMC-ZS35 Back Casing Replacement: passo 2, immagine 2 di 2
    • Use a plastic opening tool to carefully separate the back casing from the main body of the camera. It's advised to run along the entire "seam" of the casing and the camera with the tool to ensure full separation.
  3. Panasonic Lumix DMC-ZS35 Back Casing Replacement: passo 3, immagine 1 di 1
    • Gently pry apart the back casing from the body of the camera. It's recommended to apply as minimal force as is necessary to prevent unintended damage to the camera or the casing.
Conclusione
John Schug
Membro da: 02/04/20
97 Reputazione
1 Guida realizzata
UW Stout, Team S1-G2, Schneider-Bateman Spring 2020 Membro di UW Stout, Team S1-G2, Schneider-Bateman Spring 2020
UWSTOUT-SCHNEIDER-BATEMAN-S20S1G2
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 11
Tutti i Tempi: 152
