Salta al contenuto principale
Panasonic Lumix DMC-ZS3 Battery Replacement
Cosa ti serve
  1. Panasonic Lumix DMC-ZS3 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Locate the small, hinged door on the bottom of the camera.
  2. Panasonic Lumix DMC-ZS3 Battery Replacement: passo 2, immagine 1 di 1
    • Using your fingernail or a spudger, push the small, grey switch on the hinged door from the left (locked) to the right (unlocked).
    • The hinged door should swing open after unlocking.
  3. Panasonic Lumix DMC-ZS3 Battery Replacement: passo 3, immagine 1 di 1
    • Using your fingernail or a spudger, push down on the small, grey tab holding the battery in place.
    • This should release the battery.
  4. Panasonic Lumix DMC-ZS3 Battery Replacement: passo 4, immagine 1 di 2 Panasonic Lumix DMC-ZS3 Battery Replacement: passo 4, immagine 2 di 2
    • Pull the battery out of the camera.
    • The battery should slide out easily.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 21
Tutti i Tempi: 1,252
