Salta al contenuto principale
Panasonic Lumix DMC-ZS25 Screen Replacement
Cosa ti serve
  1. Panasonic Lumix DMC-ZS25  Screen Replacement, Screen: passo 1, immagine 1 di 3 Panasonic Lumix DMC-ZS25  Screen Replacement, Screen: passo 1, immagine 2 di 3 Panasonic Lumix DMC-ZS25  Screen Replacement, Screen: passo 1, immagine 3 di 3
    • Open the four 3.40 mm screws from the right and left sides of your Panasonic Lumix Camera.
    • Remove the two 2.60 mm screws located next to the battery.
  2. Panasonic Lumix DMC-ZS25  Screen Replacement: passo 2, immagine 1 di 1
    • Use the plastic opening tool to open the outer cover of your device from the HDMI port.
    • Open it carefully to avoid breaking the cover.
  3. Panasonic Lumix DMC-ZS25  Screen Replacement: passo 3, immagine 1 di 3 Panasonic Lumix DMC-ZS25  Screen Replacement: passo 3, immagine 2 di 3 Panasonic Lumix DMC-ZS25  Screen Replacement: passo 3, immagine 3 di 3
    • Use a spudger to carefully detach the ribbon cable without breaking it.
  4. Panasonic Lumix DMC-ZS25  Screen Replacement: passo 4, immagine 1 di 1
    • Use the plastic opening tool to lift and remove the buttons board as shown.
  5. Panasonic Lumix DMC-ZS25  Screen Replacement: passo 5, immagine 1 di 2 Panasonic Lumix DMC-ZS25  Screen Replacement: passo 5, immagine 2 di 2
    • Carefully lift the screen using the plastic opening tool as shown.
Conclusione
Altre 3 persone hanno completato questa guida.
Abbas Khan
Membro da: 01/21/15
482 Reputazione
4 Guide realizzate
USF Tampa, Team 9-5, Brown Winter 2015 Membro di USF Tampa, Team 9-5, Brown Winter 2015
USFT-BROWN-W15S9G5
3 Membri
7 Guide realizzate
Un commento
- Of the two 2.60 mm screws on the bottom of the camera, only the one closest to the back needs to be removed.
- The correct screwdriver is JIS Type S #00. A Phillips driver can ruin the screws.
- The screen shown in step 5 consists of two parts: the LCD and a frame. The replacement LCD that I ordered came without the frame, so a little more disassembly was required, including a bit of delicate soldering: the narrow ribbon cable is really two cables, soldered together. The solder joints are hidden under the piece of black electric tape at the end.
nasorenga - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 19
Tutti i Tempi: 4,383
