Salta al contenuto principale
Panasonic Lumix DMC-ZS25 Power Button Replacement
Cosa ti serve
  1. Panasonic Lumix DMC-ZS25  Power Button Replacement, Unscrewing your Panasonic Lumix: passo 1, immagine 1 di 3 Panasonic Lumix DMC-ZS25  Power Button Replacement, Unscrewing your Panasonic Lumix: passo 1, immagine 2 di 3 Panasonic Lumix DMC-ZS25  Power Button Replacement, Unscrewing your Panasonic Lumix: passo 1, immagine 3 di 3
    • Open the four 3.40 mm screws from the right and left sides of your Panasonic Lumix Camera.
    • Remove the two 2.60 mm screws located next to the battery.
  2. Panasonic Lumix DMC-ZS25  Power Button Replacement: passo 2, immagine 1 di 1
    • Use the plastic opening tool to open the outer cover of your device.
    • The easiest place to open your device is from the HDMI port.
    • Open it gently to avoid breaking the cover.
  3. Panasonic Lumix DMC-ZS25  Power Button Replacement: passo 3, immagine 1 di 2 Panasonic Lumix DMC-ZS25  Power Button Replacement: passo 3, immagine 2 di 2
    • Use a spudger to detach the ribbon cable.
    • Be careful when you use the spudger because you do not want to break the the ribbon.
  4. Panasonic Lumix DMC-ZS25  Power Button Replacement: passo 4, immagine 1 di 3 Panasonic Lumix DMC-ZS25  Power Button Replacement: passo 4, immagine 2 di 3 Panasonic Lumix DMC-ZS25  Power Button Replacement: passo 4, immagine 3 di 3
    • Remove the button board using the plastic opening tool.
    • Remove the screen. Lift the screen from the right hand side.
    • After your hear a "click" sound, you have successfully opened the screen.
  5. Panasonic Lumix DMC-ZS25  Power Button Replacement: passo 5, immagine 1 di 2 Panasonic Lumix DMC-ZS25  Power Button Replacement: passo 5, immagine 2 di 2
    • Remove the two black screws that are located beneath the screen.
    • Lift the metal cover using the plastic opening tool.
  6. Panasonic Lumix DMC-ZS25  Power Button Replacement: passo 6, immagine 1 di 2 Panasonic Lumix DMC-ZS25  Power Button Replacement: passo 6, immagine 2 di 2
    • Use the plastic opener to remove the side covers.
  7. Panasonic Lumix DMC-ZS25  Power Button Replacement: passo 7, immagine 1 di 2 Panasonic Lumix DMC-ZS25  Power Button Replacement: passo 7, immagine 2 di 2
    • After removing the side covers, you will be able to take away the front cover with your hands.
    • Do not apply too much pressure on the outer cover of your device to avoid damage.
  8. Panasonic Lumix DMC-ZS25  Power Button Replacement: passo 8, immagine 1 di 1
    • To release the top cover of the camera, you need to open the 3.70 mm screw shown in the picture.
  9. Panasonic Lumix DMC-ZS25  Power Button Replacement: passo 9, immagine 1 di 1
    • Remove the top cover using the plastic opening tool.
  10. Panasonic Lumix DMC-ZS25  Power Button Replacement: passo 10, immagine 1 di 3 Panasonic Lumix DMC-ZS25  Power Button Replacement: passo 10, immagine 2 di 3 Panasonic Lumix DMC-ZS25  Power Button Replacement: passo 10, immagine 3 di 3
    • After removing the top cover of the camera, you will be able to easily remove the power button with your hand.
Conclusione
Abbas Khan
Membro da: 01/21/15
482 Reputazione
4 Guide realizzate
USF Tampa, Team 9-5, Brown Winter 2015 Membro di USF Tampa, Team 9-5, Brown Winter 2015
USFT-BROWN-W15S9G5
3 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 7
Tutti i Tempi: 604
