Salta al contenuto principale
Panasonic Lumix DMC-ZS25 Lens Replacement
Cosa ti serve
  1. Panasonic Lumix DMC-ZS25  Lens  Replacement, Camera lens: passo 1, immagine 1 di 3 Panasonic Lumix DMC-ZS25  Lens  Replacement, Camera lens: passo 1, immagine 2 di 3 Panasonic Lumix DMC-ZS25  Lens  Replacement, Camera lens: passo 1, immagine 3 di 3
    • Open the four 3.40 mm screws from the right and left sides of your Panasonic Lumix Camera.
    • Remove the two 2.60 mm screws located next to the battery.
  2. Panasonic Lumix DMC-ZS25  Lens  Replacement: passo 2, immagine 1 di 1
    • Use the iFixit opening tool to open the outer cover of your device.
    • The easiest place to open your device is from the HDMI port.
    • Gently open it to avoid breaking the cover.
  3. Panasonic Lumix DMC-ZS25  Lens  Replacement: passo 3, immagine 1 di 3 Panasonic Lumix DMC-ZS25  Lens  Replacement: passo 3, immagine 2 di 3 Panasonic Lumix DMC-ZS25  Lens  Replacement: passo 3, immagine 3 di 3
    • Use a spudger to detach the ribbon cable.
    • Be careful when using the spudger, as it can cause damage to the ribbon.
    • After releasing the screen cable, use the iFixit opening tool to lift the button board.
    • Once you hear a "click" sound, you have successfully opened the buttons board.
  4. Panasonic Lumix DMC-ZS25  Lens  Replacement: passo 4, immagine 1 di 2 Panasonic Lumix DMC-ZS25  Lens  Replacement: passo 4, immagine 2 di 2
    • Remove the screen using the iFixit opening tool.
  5. Panasonic Lumix DMC-ZS25  Lens  Replacement: passo 5, immagine 1 di 2 Panasonic Lumix DMC-ZS25  Lens  Replacement: passo 5, immagine 2 di 2
    • Open the two 4.20 mm screws to remove the inner cover located beneath the screen.
    • Use the iFixit opening tool to assist in safely removing the inner cover.
  6. Panasonic Lumix DMC-ZS25  Lens  Replacement: passo 6, immagine 1 di 2 Panasonic Lumix DMC-ZS25  Lens  Replacement: passo 6, immagine 2 di 2
    • Separate the device into two pieces as shown.
  7. Panasonic Lumix DMC-ZS25  Lens  Replacement: passo 7, immagine 1 di 3 Panasonic Lumix DMC-ZS25  Lens  Replacement: passo 7, immagine 2 di 3 Panasonic Lumix DMC-ZS25  Lens  Replacement: passo 7, immagine 3 di 3
    • Remove the side cover using the iFixit opening tool.
    • Exercise caution when you remove the front cover as damage to the device can occur.
  8. Panasonic Lumix DMC-ZS25  Lens  Replacement: passo 8, immagine 1 di 3 Panasonic Lumix DMC-ZS25  Lens  Replacement: passo 8, immagine 2 di 3 Panasonic Lumix DMC-ZS25  Lens  Replacement: passo 8, immagine 3 di 3
    • Use the spudger to unlock the screen cables from the circuit bored. Carefully, lift up the black clip up to release the cables.
    • Use your hands to remove the lens.
Conclusione
Altre 2 persone hanno completato questa guida.
Abbas Khan
Membro da: 01/21/15
482 Reputazione
4 Guide realizzate
USF Tampa, Team 9-5, Brown Winter 2015 Membro di USF Tampa, Team 9-5, Brown Winter 2015
USFT-BROWN-W15S9G5
3 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 2,398
