Salta al contenuto principale
Panasonic Lumix DMC-ZS1 Door Replacement
Cosa ti serve
  1. Panasonic Lumix DMC-ZS1 Door Replacement, Exterior Screw removal: passo 1, immagine 1 di 3 Panasonic Lumix DMC-ZS1 Door Replacement, Exterior Screw removal: passo 1, immagine 2 di 3 Panasonic Lumix DMC-ZS1 Door Replacement, Exterior Screw removal: passo 1, immagine 3 di 3
    • Remove the battery and memory card from the unit
    • Remove 6 (0.3mm) screws from the sides of the unit
    • Remove 5 (0.3mm) screws from the bottom of the unit
  2. Panasonic Lumix DMC-ZS1 Door Replacement: passo 2, immagine 1 di 2 Panasonic Lumix DMC-ZS1 Door Replacement: passo 2, immagine 2 di 2
    • Lift up slightly the rear cover.
    • Do not remove rear cover yet. It is still attached to the Main PCB.
    • Flip up the cable clamps using a spudger or other device. Careful not to break the clamps. Release flex cables and remove back cover.
  3. Panasonic Lumix DMC-ZS1 Door Replacement: passo 3, immagine 1 di 3 Panasonic Lumix DMC-ZS1 Door Replacement: passo 3, immagine 2 di 3 Panasonic Lumix DMC-ZS1 Door Replacement: passo 3, immagine 3 di 3
    • Release the 3 metal clips from the rear cover and remove the LCD
  4. Panasonic Lumix DMC-ZS1 Door Replacement, Door: passo 4, immagine 1 di 3 Panasonic Lumix DMC-ZS1 Door Replacement, Door: passo 4, immagine 2 di 3 Panasonic Lumix DMC-ZS1 Door Replacement, Door: passo 4, immagine 3 di 3
    • Complete the following review guide: LCD removal
    • Remove the front cover
    • Use tweezers or a thin object to push door pin thru enough to grab from the other side.
    • Keep door closed during this procedure so you will not loose the spring.
  5. Panasonic Lumix DMC-ZS1 Door Replacement: passo 5, immagine 1 di 3 Panasonic Lumix DMC-ZS1 Door Replacement: passo 5, immagine 2 di 3 Panasonic Lumix DMC-ZS1 Door Replacement: passo 5, immagine 3 di 3
    • Try to keep the door closed during this procedure.
    • Pull out door pin using needle nose pliers or other tool.
    • Notice spring positioning. This will help you re-install your replacement door
    • If you are having trouble installing, try to keep the spring in place by using a small piece of tape.
    • Replacement Door
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 141
