Salta al contenuto principale
Introduzione
This guide is for replacing the entire camera lens assembly. It will guide you through all of the necessary steps to disassemble your camera.
Dissasembly of the lens box is not documented here and involves complex gear matching.
Parti
Nessuna parte specificata.
  1. Remove the battery and memory card from the device.
    • Remove the battery and memory card from the device.
  2. Remove 4 screws from the right side of the camera.
    • Remove 4 screws from the right side of the camera.
    • There are two 3.4mm screws at the top.
    • There are two 2.2mm screws at the bottom.
  3. Remove the single 3.4mm screw on the left side of the camera.
    • Remove the single 3.4mm screw on the left side of the camera.
  4. Remove 5 screws from the base of the camera.
    • Remove 5 screws from the base of the camera.
    • There are two 2.2mm screws next to the battery compartment.
    • There are three 4mm screws around the tripod mount.
  5. Slowly slide the back cover away from the device
    • Slowly slide the back cover away from the device
    • The back casing is held in place by two ribbon cables. Do not pull the back cover too far from the camera.
  6. Kit di riparazione batterie iPhone
    Solo $29.99
    Buy Now
    Solo $29.99
    Buy Now
  7. Detach both ribbon cables using a spudger. Use the tip of the spudger to lift the black clip upward, unlocking the ribbon cable.
    • Detach both ribbon cables using a spudger.
    • Use the tip of the spudger to lift the black clip upward, unlocking the ribbon cable.
  8. Remove the back casing from the camera.
    • Remove the back casing from the camera.
  9. Use the spudger to remove the ribbon cable connecting the lens casing to the circuit board by lifting up the black clip. Carefully remove the function switch cover. This unit snaps on and off.
    • Use the spudger to remove the ribbon cable connecting the lens casing to the circuit board by lifting up the black clip.
    • Carefully remove the function switch cover. This unit snaps on and off.
  10. Carefully unsnap the front logic board from the rear logic board using a spudger.
    • Carefully unsnap the front logic board from the rear logic board using a spudger.
  11. Slide the entire top part of the camera that is attached to the logic board, horizontally away from the camera. Slide the entire top part of the camera that is attached to the logic board, horizontally away from the camera.
    • Slide the entire top part of the camera that is attached to the logic board, horizontally away from the camera.
  12. Remove the ribbon cable from the top connection panel by unlocking the black clip with a spudger. This leaves you with the logic board and the top connection panel separate and free from the camera This leaves you with the logic board and the top connection panel separate and free from the camera
    • Remove the ribbon cable from the top connection panel by unlocking the black clip with a spudger.
    • This leaves you with the logic board and the top connection panel separate and free from the camera
  13. Use a spudger to detach the ribbon cable from the circuit board. Lift the black clip up to unlock it as before.
    • Use a spudger to detach the ribbon cable from the circuit board. Lift the black clip up to unlock it as before.
  14. Remove the 3 screws holding the lens assembly in place.
    • Remove the 3 screws holding the lens assembly in place.
    • The two screws on the left are 4.5mm with washers.
    • The single screw on the right is 4mm.
  15. Push the lens assembly slightly toward the circuit board, and pull the left side out of the casing first. You will have to wiggle this out gently.
    • Push the lens assembly slightly toward the circuit board, and pull the left side out of the casing first. You will have to wiggle this out gently.
  16. Remove the entire assembly out of the casing. The ribbons on the left and bottom of the assembly simply rest on the camera housing.
    • Remove the entire assembly out of the casing.
    • The ribbons on the left and bottom of the assembly simply rest on the camera housing.
Conclusione
Altre 12 persone hanno completato questa guida.
Brandon
Membro da: 11/10/2010
508 Reputazione
1 Guida realizzata
Cal Poly, Team 9-21, Regan Fall 2010 Membro di Cal Poly, Team 9-21, Regan Fall 2010
CPSU-REGAN-F10S9G21
4 Membri
7 Guide realizzate
I have a Lumix, not sure if it is this one, but I now have a MUCH better idea on how to proceed. I was knocked off a shelf(in case) and fell about five feet to the floor. Dang CAT! It powers on and (if I recall) will still capture an image but the display is simply white. This tells me most of the camera is functioning and the ribbon cable has become disconnected.(I hope)
I have looked for this info before and have no idea why it did not show up on DDG, Google, or SP. Thank you for this guide.
T Bob Trasman
T Bob Trasman - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 26
Tutti i Tempi: 23,877
