Introduzione
The Main PCB is one of the most important parts of the Panasonic Lumix DMC-GX85; it cannot function properly without one. Replacing a faulty Main PCB is made easy here.
Cosa ti serve
Remove the plastic hot shoe cover by sliding it towards the rear of the camera.
Turn the camera so the lens is facing down with the rear cover pulled back.
Disconnect the ribbon cable from the camera by pulling up on the black locking tab with an iFixit opening tool.
Pull the ribbon cable from the connector. The rear cover is now completely detached from the camera.
Remove the three 3.5mm silver Phillips #0 screws mounting the main PCB to the camera frame.
Altre 4 persone hanno completato questa guida.
2 Commenti
Where i can find this replacement ? DMC-GX85 Main PCB Replacement
