Salta al contenuto principale
Panasonic Lumix DMC-GF2 Front Cover Replacement
Cosa ti serve
  1. Panasonic Lumix DMC-GF2 Front Cover Replacement, Battery: passo 1, immagine 1 di 1
    • On the bottom of the camera, use your finger to push the lock button to the open position which will cause the hinged door to swing open.
  2. Panasonic Lumix DMC-GF2 Front Cover Replacement: passo 2, immagine 1 di 2 Panasonic Lumix DMC-GF2 Front Cover Replacement: passo 2, immagine 2 di 2
    • Push the small black tab that holds the battery with your finger to release the battery.
    • Use your fingers to pull the battery out of the camera.
  3. Panasonic Lumix DMC-GF2 Front Cover Replacement, Front Cover: passo 3, immagine 1 di 3 Panasonic Lumix DMC-GF2 Front Cover Replacement, Front Cover: passo 3, immagine 2 di 3 Panasonic Lumix DMC-GF2 Front Cover Replacement, Front Cover: passo 3, immagine 3 di 3
    • Using a Philips #00 screwdriver, remove six 2.69 mm screws located on the two short sides and on the bottom of the camera.
    • To loosen a screw, turn the screwdriver to the left. To tighten a screw, turn the screwdriver to the right.
  4. Panasonic Lumix DMC-GF2 Front Cover Replacement: passo 4, immagine 1 di 1
    • Using a Phillips #00 screwdriver, remove four black 2.69 mm screws from the front of the camera.
  5. Panasonic Lumix DMC-GF2 Front Cover Replacement: passo 5, immagine 1 di 1
    • Using your hand, gently lift up the front cover and separate it from the camera.
Conclusione
Baylor, Team 5-9, Williams Fall 2016 Membro di Baylor, Team 5-9, Williams Fall 2016
BU-WILLIAMS-F16S5G9
3 Membri
11 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 22
Tutti i Tempi: 996
