Salta al contenuto principale
Panasonic Lumix DMC-GF2 Back Cover Replacement
Cosa ti serve
  1. Panasonic Lumix DMC-GF2 Back Cover Replacement, Battery: passo 1, immagine 1 di 1
    • On the bottom of the camera, use your finger to push the lock button to the open position which will cause the hinged door to swing open.
  2. Panasonic Lumix DMC-GF2 Back Cover Replacement: passo 2, immagine 1 di 2 Panasonic Lumix DMC-GF2 Back Cover Replacement: passo 2, immagine 2 di 2
    • Push the small black tab that holds the battery with your finger to release the battery.
    • Use your fingers to pull the battery out of the camera.
  3. Panasonic Lumix DMC-GF2 Back Cover Replacement, Back Cover: passo 3, immagine 1 di 3 Panasonic Lumix DMC-GF2 Back Cover Replacement, Back Cover: passo 3, immagine 2 di 3 Panasonic Lumix DMC-GF2 Back Cover Replacement, Back Cover: passo 3, immagine 3 di 3
    • Using a Phillips #00 screwdriver, remove six 2.69mm, silver screws located on the two short sides of the camera and the bottom side.
  4. Panasonic Lumix DMC-GF2 Back Cover Replacement: passo 4, immagine 1 di 3 Panasonic Lumix DMC-GF2 Back Cover Replacement: passo 4, immagine 2 di 3 Panasonic Lumix DMC-GF2 Back Cover Replacement: passo 4, immagine 3 di 3
    • Gently lift up the back cover to access the ZIF connectors for the blue and yellow ribbons.
    • To unlock the ZIF connectors, gently push the black portion of the lock from a flat position to an upright position using a spudger.
    • Take caution not to rip the ribbons out of the ZIF connectors when lifting the back panel.
  5. Panasonic Lumix DMC-GF2 Back Cover Replacement: passo 5, immagine 1 di 1
    • Gently push the blue and yellow ribbons out of the unlocked ZIF connectors using your fingers.
  6. Panasonic Lumix DMC-GF2 Back Cover Replacement: passo 6, immagine 1 di 1
    • Using a Phillips #00 screwdriver, remove the 3.5 mm silver screw from the upper left hand corner of the back cover.
  7. Panasonic Lumix DMC-GF2 Back Cover Replacement: passo 7, immagine 1 di 1
    • Using a spudger, lift up and remove the plastic cover piece from the back cover.
    • Plastic cover may fall off without prying.
  8. Panasonic Lumix DMC-GF2 Back Cover Replacement: passo 8, immagine 1 di 1
    • Using a Phillips #00 screwdriver, remove the 2.69 mm silver screw located beneath the plastic piece that was previously removed.
  9. Panasonic Lumix DMC-GF2 Back Cover Replacement: passo 9, immagine 1 di 1
    • Using a spudger, lift up and separate the heavier metal cover from the light, plastic back cover.
    • Metal cover may fall off without prying.
Conclusione
Baylor, Team 5-9, Williams Fall 2016 Membro di Baylor, Team 5-9, Williams Fall 2016
BU-WILLIAMS-F16S5G9
3 Membri
11 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 22
Ultimi 30 Giorni: 65
Tutti i Tempi: 1,601
