Salta al contenuto principale
Panasonic Lumix DMC-G5 LCD Replacement
Cosa ti serve
  1. Panasonic Lumix DMC-G5 LCD Replacement, LCD: passo 1, immagine 1 di 2 Panasonic Lumix DMC-G5 LCD Replacement, LCD: passo 1, immagine 2 di 2
    • Use J0 screwdriver to remove the two 3.2 mm screws from the outside of the assembly.
    • Use the J0 screwsdriver to remove the two 5.6 mm screws from the inside of the face near the swivel.
    • Rotate the face to more easily gain access to the screws.
  2. Panasonic Lumix DMC-G5 LCD Replacement: passo 2, immagine 1 di 2 Panasonic Lumix DMC-G5 LCD Replacement: passo 2, immagine 2 di 2
    • Slide the wide plastic opening tool underneath the crack of the side of the face and separate the components.
  3. Panasonic Lumix DMC-G5 LCD Replacement: passo 3, immagine 1 di 1
    • Carefully remove the filament connections from the LCD backing by lifting the black lever up first on the connector, then pulling gently outward from the LCD backing with your fingers.
    • Replace the filament connections into the backing of the new LCD face to complete replacement..
Conclusione
USF Tampa, Team 1-3, Kass Spring 2017 Membro di USF Tampa, Team 1-3, Kass Spring 2017
USFT-KASS-S17S1G3
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 13
Tutti i Tempi: 2,107
