Salta al contenuto principale
Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement
Cosa ti serve
  1. Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement, Diopter Adjustment Dial: passo 1, immagine 1 di 3 Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement, Diopter Adjustment Dial: passo 1, immagine 2 di 3 Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement, Diopter Adjustment Dial: passo 1, immagine 3 di 3
    • Remove the four 4.6mm J000 Phillips screws from the sides and two 3.2mm J000 Phillips screws along the bottom.
  2. Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: passo 2, immagine 1 di 3 Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: passo 2, immagine 2 di 3 Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: passo 2, immagine 3 di 3
    • Remove the two 3.2mm J000 Phillips screws located on the bottom edge of the viewfinder cover.
    • Carefully remove the viewfinder cover.
    • Remove the two 4.4mm J000 Phillips screws located near the top edge of the viewfinder.
  3. Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: passo 3, immagine 1 di 3 Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: passo 3, immagine 2 di 3 Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: passo 3, immagine 3 di 3
    • Slide the Wide Plastic Opening Tool upwards along the underside of the rear casing.
    • Be careful not to disconnect the filament connections. Reinserting them can be difficult.
    • Slowly lower the casing into the position shown.
  4. Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: passo 4, immagine 1 di 2 Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: passo 4, immagine 2 di 2
    • Use the Screwdriver J000 Phillips Head to remove the screw located at the lower-left corner of the face of the viewfinder glass.
    • Carefully lift the L-shaped clicker underneath the previously removed screw.
  5. Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: passo 5, immagine 1 di 2 Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: passo 5, immagine 2 di 2
    • Slide the faulty diopter adjustment dial off the rod.
    • Replace the diopter dial with a 1-cm wheel.
Conclusione
USF Tampa, Team 1-3, Kass Spring 2017 Membro di USF Tampa, Team 1-3, Kass Spring 2017
USFT-KASS-S17S1G3
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,060
