Salta al contenuto principale
  1. Make sure the power is off by switching  the power switch to the left.
    • Make sure the power is off by switching the power switch to the left.
  2. Use a Phillips #00 screwdriver to remove the screws on the left side of the camera. Use a Phillips #00 screwdriver to remove the screws on the left side of the camera.
    • Use a Phillips #00 screwdriver to remove the screws on the left side of the camera.
  3. Kit riparazione batterie MacBook
    A partire da $69.99
    Buy Now
    A partire da $69.99
    Buy Now
  4. Remove the screws on the right side of the camera by using the Philips #00 screwdriver.
    • Remove the screws on the right side of the camera by using the Philips #00 screwdriver.
  5. Remove the screws on the bottom side of the camera using the Philips #00 Screwdriver. Separate the covers by gently applying force upwards, carefully placing the opening tool between the two covers.
    • Remove the screws on the bottom side of the camera using the Philips #00 Screwdriver.
    • Separate the covers by gently applying force upwards, carefully placing the opening tool between the two covers.
  6. Lift the ZIF tabs up with the opening tool and carefully remove the digitizer ribbon cables. Remove the LCD Screen from the glass frame carefully with the opening tool.
    • Lift the ZIF tabs up with the opening tool and carefully remove the digitizer ribbon cables.
    • Remove the LCD Screen from the glass frame carefully with the opening tool.
  7. Push on the back panel buttons on the front side to remove the buttons. Be cautious of the adhesive holding the button panels to the cover. Apply extra force if necessary.
    • Push on the back panel buttons on the front side to remove the buttons.
    • Be cautious of the adhesive holding the button panels to the cover. Apply extra force if necessary.
Conclusione
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 51
