Salta al contenuto principale
Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement
Cosa ti serve
  1. Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement, Loose Digitizer Cable: passo 1, immagine 1 di 1
    • Power off your device by locating the on/off switch on top of camera.
  2. Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: passo 2, immagine 1 di 3 Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: passo 2, immagine 2 di 3 Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: passo 2, immagine 3 di 3
    • Remove the screw located on the right side of the camera.
    • Remove the screw located on the bottom right of the camera, and remove the cover from the camera.
  3. Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: passo 3, immagine 1 di 1
    • Remove the screw located on the base of the camera.
  4. Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: passo 4, immagine 1 di 1
    • Pry the top part of the camera slowly. Be careful not to tear the digitilizer cable.
  5. Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: passo 5, immagine 1 di 2 Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: passo 5, immagine 2 di 2
    • Open the bigger clamp using a spudger or other tools. Repeat for the smaller clamp.
  6. Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: passo 6, immagine 1 di 2 Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: passo 6, immagine 2 di 2
    • Carefully take the thin ribbon and insert cable end into the latch. Do this for both sides.
  7. Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: passo 7, immagine 1 di 3 Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: passo 7, immagine 2 di 3 Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: passo 7, immagine 3 di 3
    • Once the ribbon is placed into the latch, carefully close the clamps by lowering the clamp into a down position. Repeat this step for both sides.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 350
