Salta al contenuto principale
Panasonic Lumix DMC-FX37 Disassembly
Cosa ti serve
  1. Panasonic Lumix DMC-FX37 Disassembly, Panasonic Lumix DMC-FX37 Disassembly: passo 1, immagine 1 di 2 Panasonic Lumix DMC-FX37 Disassembly, Panasonic Lumix DMC-FX37 Disassembly: passo 1, immagine 2 di 2
    • Remove both of the 3 mm screws on the bottom of the camera connected to the side panel.
  2. Panasonic Lumix DMC-FX37 Disassembly: passo 2, immagine 1 di 2 Panasonic Lumix DMC-FX37 Disassembly: passo 2, immagine 2 di 2
    • Remove the remaining 3 mm screw holding on the side panel and remove the panel entirely.
  3. Panasonic Lumix DMC-FX37 Disassembly: passo 3, immagine 1 di 2 Panasonic Lumix DMC-FX37 Disassembly: passo 3, immagine 2 di 2
    • On the opposite side of the camera, remove the two 3 mm screws.
    • Remove the bottom side panel and place it with its respective 3 mm screw.
  4. Panasonic Lumix DMC-FX37 Disassembly: passo 4, immagine 1 di 3 Panasonic Lumix DMC-FX37 Disassembly: passo 4, immagine 2 di 3 Panasonic Lumix DMC-FX37 Disassembly: passo 4, immagine 3 di 3
    • Remove the front panel (the panel around the lens casing) from the camera.
    • Remove the two ribbon cables connected to the back panel (the panel this the LCD screen) by lifting up on their respective tabs and gently pulling out the cord.
    • Caution: When removing the back panel, the two ribbon cables are relatively delicate and must both be disconnected before the panel can be entirely removed.
    • Remove the back panel from the camera.
  5. Panasonic Lumix DMC-FX37 Disassembly: passo 5, immagine 1 di 1
    • Remove the top control panel (connected to the flash battery) from the camera.
    • The top control panel is connected to the rest of the camera by a delicate multi-pin plug. Be careful as to not bend the pins!
Conclusione
Baylor, Team S2-G3, Johnson Spring 2018 Membro di Baylor, Team S2-G3, Johnson Spring 2018
BU-JOHNSON-S18S2G3
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 12
Tutti i Tempi: 581
