Introduzione
This guide will demonstrate how to install the USB Ports on your camera.
Parti
Nessuna parte richiesta.
Move the switch on the battery door to the Open position.
  • Move the switch on the battery door to the Open position.
  • The door will automatically swing open after you let it go.
Aggiungi Commento
Push the small gray tab on the top right corner to the left. The battery will pop out slightly.
  • Push the small gray tab on the top right corner to the left. The battery will pop out slightly.
  • Keep your finger clear of the battery when it pops out.
Aggiungi Commento
  • Push the memory card in and let go.
  • The memory card will pop out slightly.
  • Pull out the memory card.
Aggiungi Commento
  • Unscrew the small screws on the sides of the camera.
  • The screws on the left side(#00P, 4.7mm) are longer than the screw on the right side(#00P, 3.3mm).
Aggiungi Commento
  • Unscrew the three small screws on the bottom(#00P, 3.3mm).
  • The bottom will fall off.
Aggiungi Commento
  • Lift up the bottom back cover by prying the bottom edge with the spudger.
  • Gently lift up the back cover with your hand from the bottom to the top.
Aggiungi Commento
  • Lift the tabs on the ZIF connectors.
  • The ribbon cables should easily come out of the ZIF connectors.
Aggiungi Commento
  • Using the spudger, pry off the top cover by gliding the spudger along the entire edge between the top cover and the front cover.
  • Be careful not to damage the cylindrical capacitor on the circuit board under the top cover.
Aggiungi Commento
  • Remove the small screw in the hole towards the top of the camera(#00P, 5.4mm).
Aggiungi Commento
  • Use the spudger to lift up the back logic board.
  • Using your fingers, gently wiggle and pull off the back motherboard.
  • You will hear a click when you lift it up.
Aggiungi Commento
  • Remove the small screw holding down the lower motherboard(#00P, 3.2mm).
Aggiungi Commento
  • Use the spudger to lift the upper tab from the main housing.
  • Gently lift the lower tab from the main body by prying it with your finger.
  • Gently pull off the plastic motherboard housing sideways.
Aggiungi Commento
  • Gently lift the tabs on the ZIF connectors connecting the lens to the front motherboard.
  • Once you lift the tabs the ribbons should fall right out and the front motherboard should be free.
Aggiungi Commento
  • The USB port is hardwired into this motherboard.
Aggiungi Commento
Conclusione
Karissa
Membro da: 13/04/2012
50 Reputazione
8 Guide realizzate
Cal Poly, Team 6-23, Amido Spring 2012 Membro di Cal Poly, Team 6-23, Amido Spring 2012
CPSU-AMIDO-S12S6G23
4 Membri
10 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 624
