Salta al contenuto principale
Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement
Cosa ti serve
  1. Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement, Battery: passo 1, immagine 1 di 1
    • Move the switch on the battery door to the Open position.
    • The door will automatically swing open after you let it go.
  2. Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement: passo 2, immagine 1 di 2 Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement: passo 2, immagine 2 di 2
    • Push the small gray tab on the top right corner to the left. The battery will pop out slightly.
    • Keep your finger clear of the battery when it pops out.
  3. Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement, Memory Card: passo 3, immagine 1 di 1
    • Push the memory card in and let go.
    • The memory card will pop out slightly.
    • Pull out the memory card.
  4. Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement, Back Cover: passo 4, immagine 1 di 2 Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement, Back Cover: passo 4, immagine 2 di 2
    • Unscrew the small screws on the sides of the camera.
    • The screws on the left side(#00P, 4.7mm) are longer than the screw on the right side(#00P, 3.3mm).
  5. Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement: passo 5, immagine 1 di 2 Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement: passo 5, immagine 2 di 2
    • Unscrew the three small screws on the bottom(#00P, 3.3mm).
    • The bottom will fall off.
  6. Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement: passo 6, immagine 1 di 3 Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement: passo 6, immagine 2 di 3 Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement: passo 6, immagine 3 di 3
    • Lift up the bottom back cover by prying the bottom edge with the spudger.
    • Gently lift up the back cover with your hand from the bottom to the top.
  7. Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement: passo 7, immagine 1 di 3 Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement: passo 7, immagine 2 di 3 Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement: passo 7, immagine 3 di 3
    • Lift the tabs on the ZIF connectors.
    • The ribbon cables should easily come out of the ZIF connectors.
  8. Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement, Back Panel Buttons: passo 8, immagine 1 di 2 Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement, Back Panel Buttons: passo 8, immagine 2 di 2
    • Gently wiggle out the top motherboard.
    • The buttons are hardwired into this logic board.
Conclusione
Karissa
Membro da: 04/13/12
50 Reputazione
8 Guide realizzate
Cal Poly, Team 6-23, Amido Spring 2012 Membro di Cal Poly, Team 6-23, Amido Spring 2012
CPSU-AMIDO-S12S6G23
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 804
