Salta al contenuto principale
Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement
Cosa ti serve
  1. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement, Battery: passo 1, immagine 1 di 1
    • Locate the memory card and battery card latch on the bottom of the camera.
    • Slide the latch to the open position.
  2. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: passo 2, immagine 1 di 1
    • Open the battery latch, and slide the battery release lever to the right.
  3. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: passo 3, immagine 1 di 1
    • Remove the battery from the camera.
  4. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement, Rear Casing: passo 4, immagine 1 di 1
    • Remove the three 4.6 mm screws on the bottom of the camera using a Phillips #00 screwdriver.
  5. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: passo 5, immagine 1 di 1
    • Remove the single 3.2 mm screw on the left side of the camera using a Phillips #00 screwdriver.
  6. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: passo 6, immagine 1 di 2 Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: passo 6, immagine 2 di 2
    • Remove the left side casing.
  7. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: passo 7, immagine 1 di 1
    • Remove the two 3.2 mm screws on the right side of the camera using a Phillips #00 screwdriver.
  8. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: passo 8, immagine 1 di 1
    • Remove the bottom right panel.
  9. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: passo 9, immagine 1 di 2 Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: passo 9, immagine 2 di 2
    • Gently remove the back casing.
    • Start at the bottom and carefully pry towards the top to get this piece free.
  10. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement, LCD Screen: passo 10, immagine 1 di 1
    • Gently lift up the LCD screen.
    • Using a plastic prying tool, flip up the latch that holds the thin ribbon in place.
    • It should fall out on its own or with a gentle tug.
  11. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: passo 11, immagine 1 di 1
    • Gently tug the thicker ribbon to remove it from its housing.
  12. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement, On/ Off Button and Settings Button: passo 12, immagine 1 di 2 Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement, On/ Off Button and Settings Button: passo 12, immagine 2 di 2
    • Carefully remove the upper assembly, which houses the buttons and the flash battery.
  13. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: passo 13, immagine 1 di 1
    • Remove the two 3mm screws.
  14. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: passo 14, immagine 1 di 2 Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: passo 14, immagine 2 di 2
    • Pry bars back gently as shown.
    • Fingers can be used but tool is shown for clarity.
  15. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: passo 15, immagine 1 di 2 Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: passo 15, immagine 2 di 2
    • After, releasing all the components, gently remove the flash assembly from the casing.
  16. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: passo 16, immagine 1 di 1
    • Remove the 1.2 mm screw from the settings wheel.
  17. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: passo 17, immagine 1 di 1
    • Replace buttons.
    • Replace the "On/ Off" button with the prongs facing away from the flash.
Conclusione
Altre 2 persone hanno completato questa guida.
Andrew
Membro da: 10/11/10
396 Reputazione
4 Guide realizzate
Cal Poly, Team 9-22, Regan Fall 2010 Membro di Cal Poly, Team 9-22, Regan Fall 2010
CPSU-REGAN-F10S9G22
4 Membri
8 Guide realizzate
Un commento
Olá ! Sugiro ter cuidado com a carga do capacitor do flash, melhor descarrega-lo com auxílio de uma lâmpada ou resistor
para evitar um choque elétrico.
Ricardo Britto - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 6
Tutti i Tempi: 5,085
