Salta al contenuto principale
Panasonic Lumix DMC-FX01 Front Casing Replacement
Cosa ti serve
  1. Panasonic Lumix DMC-FX01 Front Casing Replacement, Battery: passo 1, immagine 1 di 1
    • Locate the memory card and battery card latch on the bottom of the camera.
    • Slide the latch to the open position.
  2. Panasonic Lumix DMC-FX01 Front Casing Replacement: passo 2, immagine 1 di 1
    • Open the battery latch, and slide the battery release lever to the right.
  3. Panasonic Lumix DMC-FX01 Front Casing Replacement: passo 3, immagine 1 di 1
    • Remove the battery from the camera.
  4. Panasonic Lumix DMC-FX01 Front Casing Replacement, Rear Casing: passo 4, immagine 1 di 1
    • Remove the three 4.6 mm screws on the bottom of the camera using a Phillips #00 screwdriver.
  5. Panasonic Lumix DMC-FX01 Front Casing Replacement: passo 5, immagine 1 di 1
    • Remove the single 3.2 mm screw on the left side of the camera using a Phillips #00 screwdriver.
  6. Panasonic Lumix DMC-FX01 Front Casing Replacement: passo 6, immagine 1 di 2 Panasonic Lumix DMC-FX01 Front Casing Replacement: passo 6, immagine 2 di 2
    • Remove the left side casing.
  7. Panasonic Lumix DMC-FX01 Front Casing Replacement: passo 7, immagine 1 di 1
    • Remove the two 3.2 mm screws on the right side of the camera using a Phillips #00 screwdriver.
  8. Panasonic Lumix DMC-FX01 Front Casing Replacement: passo 8, immagine 1 di 1
    • Remove the bottom right panel.
  9. Panasonic Lumix DMC-FX01 Front Casing Replacement: passo 9, immagine 1 di 2 Panasonic Lumix DMC-FX01 Front Casing Replacement: passo 9, immagine 2 di 2
    • Gently remove the back casing.
    • Start at the bottom and carefully pry towards the top to get this piece free.
  10. Panasonic Lumix DMC-FX01 Front Casing Replacement, LCD Screen: passo 10, immagine 1 di 1
    • Gently lift up the LCD screen.
    • Using a plastic prying tool, flip up the latch that holds the thin ribbon in place.
    • It should fall out on its own or with a gentle tug.
  11. Panasonic Lumix DMC-FX01 Front Casing Replacement: passo 11, immagine 1 di 1
    • Gently tug the thicker ribbon to remove it from its housing.
  12. Panasonic Lumix DMC-FX01 Front Casing Replacement, Front Casing: passo 12, immagine 1 di 2 Panasonic Lumix DMC-FX01 Front Casing Replacement, Front Casing: passo 12, immagine 2 di 2
    • Remove the two black 5.4 mm screws that hold in the front faceplate using a Phillips #00 screwdriver.
    • There may be a third screw the the right of the lens assembly.
  13. Panasonic Lumix DMC-FX01 Front Casing Replacement: passo 13, immagine 1 di 3 Panasonic Lumix DMC-FX01 Front Casing Replacement: passo 13, immagine 2 di 3 Panasonic Lumix DMC-FX01 Front Casing Replacement: passo 13, immagine 3 di 3
    • Carefully remove the upper assembly, which houses the buttons and the flash battery.
  14. Panasonic Lumix DMC-FX01 Front Casing Replacement: passo 14, immagine 1 di 1
    • Carefully remove the front casing after verifying that the thin plastic around the lens is not still attached.
Conclusione
Altre 2 persone hanno completato questa guida.
Andrew
Membro da: 10/11/10
396 Reputazione
4 Guide realizzate
Cal Poly, Team 9-22, Regan Fall 2010 Membro di Cal Poly, Team 9-22, Regan Fall 2010
CPSU-REGAN-F10S9G22
4 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 4,303
