Salta al contenuto principale
Panasonic Lumix DMC-FH20 Memory Card Replacement
  1. Panasonic Lumix DMC-FH20 Memory Card Replacement, Memory Card: passo 1, immagine 1 di 3 Panasonic Lumix DMC-FH20 Memory Card Replacement, Memory Card: passo 1, immagine 2 di 3 Panasonic Lumix DMC-FH20 Memory Card Replacement, Memory Card: passo 1, immagine 3 di 3
    • On the bottom of the camera, move the gray switch that has the words "open" and "lock" above it to the open position. The case will open.
  2. Panasonic Lumix DMC-FH20 Memory Card Replacement: passo 2, immagine 1 di 1
    • Once the case is open, you will see your memory card in the marked slot. Push the card down until you hear a small click. The card will then pop out and you will be able to remove it.
Conclusione
Cal Poly, Team 10-7, Banghart Winter 2017 Membro di Cal Poly, Team 10-7, Banghart Winter 2017
CPSU-BANGHART-W17S10G7
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 9
Tutti i Tempi: 317
