Introduzione
If your lens is cracked or broken, follow this guide to replace it. You will need special tools in order to complete this guide. Please refer to the tools to make sure you have what you need. Please be careful of cracked lenses as they could potentially cut you.
Cosa ti serve
Remove all screws (Phillips #000 head) from the sides and bottom of the camera.
Unscrew one screw (Phillips #000 head)
Remove the screen. You will want to use a plastic opening tool to complete this step. Pop the thin black piece of plastic upwards with the opening tool to unlock the plastic film ribbon.
Once unlocked, you will be able to pull the ribbon out and remove the screen completely.
