Salta al contenuto principale
Panasonic Lumix DMC-FH20 Lens Replacement
Cosa ti serve
  1. Panasonic Lumix DMC-FH20 Lens Replacement, Lens: passo 1, immagine 1 di 3 Panasonic Lumix DMC-FH20 Lens Replacement, Lens: passo 1, immagine 2 di 3 Panasonic Lumix DMC-FH20 Lens Replacement, Lens: passo 1, immagine 3 di 3
    • Remove all screws (Phillips #000 head) from the sides and bottom of the camera.
  2. Panasonic Lumix DMC-FH20 Lens Replacement: passo 2, immagine 1 di 2 Panasonic Lumix DMC-FH20 Lens Replacement: passo 2, immagine 2 di 2
    • Remove the back panel. This might require some extra force. If you still can't get the panel off, try to use a plastic opening tool.
  3. Panasonic Lumix DMC-FH20 Lens Replacement: passo 3, immagine 1 di 2 Panasonic Lumix DMC-FH20 Lens Replacement: passo 3, immagine 2 di 2
    • Remove the circuit board. You should be able to do this with your fingers. Just grab it and pull upwards. If it does not come, use a plastic opening tool to help.
  4. Panasonic Lumix DMC-FH20 Lens Replacement: passo 4, immagine 1 di 2 Panasonic Lumix DMC-FH20 Lens Replacement: passo 4, immagine 2 di 2
    • Remove the white plastic cover. This may take some extra force. You will want to try to remove from the bottom side first and peel up.
    • Then, where the silver switch is located, it will slide directly out at the top.
  5. Panasonic Lumix DMC-FH20 Lens Replacement: passo 5, immagine 1 di 3 Panasonic Lumix DMC-FH20 Lens Replacement: passo 5, immagine 2 di 3 Panasonic Lumix DMC-FH20 Lens Replacement: passo 5, immagine 3 di 3
    • Unscrew one screw (Phillips #000 head)
    • Remove the screen. You will want to use a plastic opening tool to complete this step. Pop the thin black piece of plastic upwards with the opening tool to unlock the plastic film ribbon.
    • Once unlocked, you will be able to pull the ribbon out and remove the screen completely.
  6. Panasonic Lumix DMC-FH20 Lens Replacement: passo 6, immagine 1 di 3 Panasonic Lumix DMC-FH20 Lens Replacement: passo 6, immagine 2 di 3 Panasonic Lumix DMC-FH20 Lens Replacement: passo 6, immagine 3 di 3
    • Remove the grey panel.
    • You will need to unscrew three screws (Phillips #000 head) in order to remove the panel.
  7. Panasonic Lumix DMC-FH20 Lens Replacement: passo 7, immagine 1 di 3 Panasonic Lumix DMC-FH20 Lens Replacement: passo 7, immagine 2 di 3 Panasonic Lumix DMC-FH20 Lens Replacement: passo 7, immagine 3 di 3
    • Pop the two thin black pieces of plastic upwards with the opening tool to unlock the plastic film ribbons.
    • Once unlocked, you will need to unscrew six more screws (Phillips #000 head) to completely detach the lens from the rest of the camera.
  8. Panasonic Lumix DMC-FH20 Lens Replacement: passo 8, immagine 1 di 2 Panasonic Lumix DMC-FH20 Lens Replacement: passo 8, immagine 2 di 2
    • Remove the lens from the camera carefully. You can do this simply by grabbing it with your fingers and pulling out gently.
Conclusione
Cal Poly, Team 10-7, Banghart Winter 2017 Membro di Cal Poly, Team 10-7, Banghart Winter 2017
CPSU-BANGHART-W17S10G7
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 26
Tutti i Tempi: 915
