Salta al contenuto principale
Panasonic Lumix DMC-FH20 LCD Screen Replacement
Cosa ti serve
  1. Panasonic Lumix DMC-FH20 LCD Screen Replacement, LCD Screen: passo 1, immagine 1 di 3 Panasonic Lumix DMC-FH20 LCD Screen Replacement, LCD Screen: passo 1, immagine 2 di 3 Panasonic Lumix DMC-FH20 LCD Screen Replacement, LCD Screen: passo 1, immagine 3 di 3
    • Remove all screws (Phillips #000 head) from the sides and bottom of the camera.
  2. Panasonic Lumix DMC-FH20 LCD Screen Replacement: passo 2, immagine 1 di 1
    • Remove the back panel. This might require some extra force. If you still can't get the panel off, try to use a plastic opening tool.
  3. Panasonic Lumix DMC-FH20 LCD Screen Replacement: passo 3, immagine 1 di 2 Panasonic Lumix DMC-FH20 LCD Screen Replacement: passo 3, immagine 2 di 2
    • Remove the circuit board. You should be able to do this with your fingers. Just grab it and pull upwards. If it does not come, use a plastic opening tool to help.
  4. Panasonic Lumix DMC-FH20 LCD Screen Replacement: passo 4, immagine 1 di 2 Panasonic Lumix DMC-FH20 LCD Screen Replacement: passo 4, immagine 2 di 2
    • Remove the white plastic cover. This may take some extra force. You will want to try to remove from the bottom side first and peel up.
    • Then, where the silver switch is located, it will slide directly out at the top.
  5. Panasonic Lumix DMC-FH20 LCD Screen Replacement: passo 5, immagine 1 di 1
    • Unscrew one screw (Phillips #000 head).
  6. Panasonic Lumix DMC-FH20 LCD Screen Replacement: passo 6, immagine 1 di 3 Panasonic Lumix DMC-FH20 LCD Screen Replacement: passo 6, immagine 2 di 3 Panasonic Lumix DMC-FH20 LCD Screen Replacement: passo 6, immagine 3 di 3
    • You will want to use a plastic opening tool to complete this step. Pop the thin black piece of plastic upwards with the opening tool to unlock the plastic film ribbon.
    • Once unlocked, you will be able to pull the ribbon out and remove the screen completely.
Conclusione
Cal Poly, Team 10-7, Banghart Winter 2017 Membro di Cal Poly, Team 10-7, Banghart Winter 2017
CPSU-BANGHART-W17S10G7
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 584
