Salta al contenuto principale
Panasonic Lumix DMC-FH20 Circuit Board Replacement
Cosa ti serve
  1. Panasonic Lumix DMC-FH20 Circuit Board Replacement, Circuit Board: passo 1, immagine 1 di 3 Panasonic Lumix DMC-FH20 Circuit Board Replacement, Circuit Board: passo 1, immagine 2 di 3 Panasonic Lumix DMC-FH20 Circuit Board Replacement, Circuit Board: passo 1, immagine 3 di 3
    • Remove all screws (Phillips #000 head) from the sides and bottom of the camera.
  2. Panasonic Lumix DMC-FH20 Circuit Board Replacement: passo 2, immagine 1 di 1
    • Remove the back panel. This might require some extra force. If you still can't get the panel off, try to use a plastic opening tool.
  3. Panasonic Lumix DMC-FH20 Circuit Board Replacement: passo 3, immagine 1 di 2 Panasonic Lumix DMC-FH20 Circuit Board Replacement: passo 3, immagine 2 di 2
    • Remove the circuit board. You should be able to do this with your fingers. Just grab it and pull upwards. If it does not come, use a plastic opening tool to help.
Conclusione
Cal Poly, Team 10-7, Banghart Winter 2017 Membro di Cal Poly, Team 10-7, Banghart Winter 2017
CPSU-BANGHART-W17S10G7
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 356
