Introduzione
Replacing the front case of your camera.
Cosa ti serve
Slide the lock switch to the right so that it is in the unlocked position.
Use your finger to slide the battery hatch in the direction of the downward arrow so that the hatch is open.
Using the Phillips #00 screwdriver, remove the two 2.8 mm screws located under the hatch.
Place the camera on a flat surface with the front side facing down.
Use the spudger to flip up the retaining flap and slide the ribbon cable out of the connector.
Hold down on the camera's metal casing with one hand. Using your other hand, remove the back case from the rest of the camera.
Remove the last two 2.8 mm Phillips #00 screws from the bottom of the camera.
