Salta al contenuto principale
Panasonic KX-TGE233 Base Front Panel Assembly Replacement
Cosa ti serve
  1. Panasonic KX-TGE233 Base Front Panel Assembly Replacement, Base Front Panel Assembly: passo 1, immagine 1 di 1
    • To fix this component, we'll need to work with the main docking station. This is the one with the answering machine and the TEL line.
  2. Panasonic KX-TGE233 Base Front Panel Assembly Replacement: passo 2, immagine 1 di 1
    • To start, we'll need to work with objects on the bottom of the device, so begin by flipping the device over.
  3. Panasonic KX-TGE233 Base Front Panel Assembly Replacement: passo 3, immagine 1 di 1
    • To open the main docking station, you'll need to remove four 11 mm Philips #0 screws.
  4. Panasonic KX-TGE233 Base Front Panel Assembly Replacement: passo 4, immagine 1 di 1
    • With the screws removed, you can use a spudger to aid in removing the back from the device.
    • Levering the back by the spudger may break the tool!
  5. Panasonic KX-TGE233 Base Front Panel Assembly Replacement: passo 5, immagine 1 di 1
    • With the back removed, we now have direct access to all other components in the main docking station.
Conclusione
IUPUI, Team 2-2, Baechle Spring 2016 Membro di IUPUI, Team 2-2, Baechle Spring 2016
IUPUI-BAECHLE-S16S2G2
5 Membri
15 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 10
Tutti i Tempi: 301
