Salta al contenuto principale
Panasonic KX-TG6641 Base Display Screen Replacement
Cosa ti serve
  1. Panasonic KX-TG6641 Base Display Screen Replacement, Base Display Screen: passo 1, immagine 1 di 1
    • Use a Phillips #0 screwdriver to remove five screws from the back cover.
  2. Panasonic KX-TG6641 Base Display Screen Replacement: passo 2, immagine 1 di 1
    • To remove the back cover, use an iFixit opening tool and wedge the tool in between the loosened back charging case and the front plate.
    • Wiggle to loosen, be careful to not pry too hard as it could cause damage.
  3. Panasonic KX-TG6641 Base Display Screen Replacement: passo 3, immagine 1 di 2 Panasonic KX-TG6641 Base Display Screen Replacement: passo 3, immagine 2 di 2
    • To access the display screen, use a Phillips #0 screwdriver to remove the screw on the bottom right corner of the electrical panel.
    • Unclip the wires hooked into the base.
    • It's not necessary to desolder the wires.
  4. Panasonic KX-TG6641 Base Display Screen Replacement: passo 4, immagine 1 di 1
    • Disconnect the two phone cable connectors.
    • Use a Phillips #0 to remove the screw that is fixed in the plastic holder for the connectors.
  5. Panasonic KX-TG6641 Base Display Screen Replacement: passo 5, immagine 1 di 2 Panasonic KX-TG6641 Base Display Screen Replacement: passo 5, immagine 2 di 2
    • Move the electrical panel to the side.
    • Use a Phillips #0 to remove the four screws from the brown board and lift it to access the display screen.
    • Be aware, there is a screw under the control panel, it is indicated with the central red circle.
  6. Panasonic KX-TG6641 Base Display Screen Replacement: passo 6, immagine 1 di 1
    • Remove the current display screen from the electric panel.
    • Follow this process in reverse to replace the new display screen in its place.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 15
Tutti i Tempi: 409
