Salta al contenuto principale
Panasonic KX-TG6021M Front Speaker Replacement
Cosa ti serve
  1. Panasonic KX-TG6021M Front Speaker Replacement, Battery: passo 1, immagine 1 di 2 Panasonic KX-TG6021M Front Speaker Replacement, Battery: passo 1, immagine 2 di 2
    • Slide the back cover down towards the bottom of the phone to remove.
  2. Panasonic KX-TG6021M Front Speaker Replacement: passo 2, immagine 1 di 3 Panasonic KX-TG6021M Front Speaker Replacement: passo 2, immagine 2 di 3 Panasonic KX-TG6021M Front Speaker Replacement: passo 2, immagine 3 di 3
    • Pull the top of the battery towards you to remove it from the phone.
  3. Panasonic KX-TG6021M Front Speaker Replacement, Front Panel: passo 3, immagine 1 di 2 Panasonic KX-TG6021M Front Speaker Replacement, Front Panel: passo 3, immagine 2 di 2
    • Unscrew the two screws located at the bottom of the phone.
    • Use a PH00 Phillips head to remove the 9 mm screws.
  4. Panasonic KX-TG6021M Front Speaker Replacement: passo 4, immagine 1 di 3 Panasonic KX-TG6021M Front Speaker Replacement: passo 4, immagine 2 di 3 Panasonic KX-TG6021M Front Speaker Replacement: passo 4, immagine 3 di 3
    • Separate the back cover from the front cover by using a wedge.
    • Remove the back cover from the front cover by pulling them apart.
  5. Panasonic KX-TG6021M Front Speaker Replacement: passo 5, immagine 1 di 1
    • Remove three screws on the motherboard.
    • Pull the phone face off of the motherboard.
  6. Panasonic KX-TG6021M Front Speaker Replacement, Front Speaker: passo 6, immagine 1 di 1
    • Remove the front speaker housing by detaching it from the circuit board.
  7. Panasonic KX-TG6021M Front Speaker Replacement: passo 7, immagine 1 di 1
    • Pop out the front speaker from the housing.
  8. Panasonic KX-TG6021M Front Speaker Replacement: passo 8, immagine 1 di 1
    • Desolder the two connections and remove the wires from the circuit board.
Conclusione
paul scruggs
Membro da: 10/24/16
177 Reputazione
1 Guida realizzata
IUPUI, Team 3-1, Baechle Fall 2016 Membro di IUPUI, Team 3-1, Baechle Fall 2016
IUPUI-BAECHLE-F16S3G1
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 212
