Salta al contenuto principale
Panasonic KX-TG6021M Back Speaker Replacement
Cosa ti serve
  1. Panasonic KX-TG6021M Back Speaker Replacement, Battery: passo 1, immagine 1 di 2 Panasonic KX-TG6021M Back Speaker Replacement, Battery: passo 1, immagine 2 di 2
    • Slide the back cover down towards the bottom of the phone to remove.
  2. Panasonic KX-TG6021M Back Speaker Replacement: passo 2, immagine 1 di 3 Panasonic KX-TG6021M Back Speaker Replacement: passo 2, immagine 2 di 3 Panasonic KX-TG6021M Back Speaker Replacement: passo 2, immagine 3 di 3
    • Pull the top of the battery towards you to remove it from the phone.
  3. Panasonic KX-TG6021M Back Speaker Replacement, Front Panel: passo 3, immagine 1 di 2 Panasonic KX-TG6021M Back Speaker Replacement, Front Panel: passo 3, immagine 2 di 2
    • Unscrew the two screws located at the bottom of the phone.
    • Use a PH00 Phillips head to remove the 9 mm screws.
  4. Panasonic KX-TG6021M Back Speaker Replacement: passo 4, immagine 1 di 3 Panasonic KX-TG6021M Back Speaker Replacement: passo 4, immagine 2 di 3 Panasonic KX-TG6021M Back Speaker Replacement: passo 4, immagine 3 di 3
    • Separate the back cover from the front cover by using a wedge.
    • Remove the back cover from the front cover by pulling them apart.
  5. Panasonic KX-TG6021M Back Speaker Replacement: passo 5, immagine 1 di 1
    • Remove three screws on the motherboard.
    • Pull the phone face off of the motherboard.
  6. Panasonic KX-TG6021M Back Speaker Replacement, Back Speaker: passo 6, immagine 1 di 1
    • Twist the back speaker and pull straight out to remove it from the case.
    • To completely remove the speaker from the motherboard, you will need to desolder the speaker cables.
Conclusione
Leah Meador
Membro da: 10/24/16
301 Reputazione
2 Guide realizzate
IUPUI, Team 3-1, Baechle Fall 2016 Membro di IUPUI, Team 3-1, Baechle Fall 2016
IUPUI-BAECHLE-F16S3G1
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 9
Tutti i Tempi: 613
