Introduzione
Once the back cover has been removed, removing the antenna is as simple as unscrewing one screw.
Parti
Nessuna parte richiesta.
Orient the phone so that the phone model and other descriptive information is facing upward. Locate the two silver screws near the hinge where the battery is housed.
  • Orient the phone so that the phone model and other descriptive information is facing upward.
  • Locate the two silver screws near the hinge where the battery is housed.
  • Remove the silver screws using a Phillips head #2 screwdriver.
Aggiungi Commento
Pull off the back panel of the phone. Make sure you pull the cover off carefully in order to prevent damage to the back cover. Make sure you pull the cover off carefully in order to prevent damage to the back cover.
  • Pull off the back panel of the phone.
  • Make sure you pull the cover off carefully in order to prevent damage to the back cover.
Aggiungi Commento
Find the silver screw located in the red circle. Using a Philips head #2 screwdriver, remove the screw holding the antenna in place.
  • Find the silver screw located in the red circle.
  • Using a Philips head #2 screwdriver, remove the screw holding the antenna in place.
Aggiungi Commento
Press the release button. The release button is located in the red circle in the image to the left.
  • Press the release button.
  • The release button is located in the red circle in the image to the left.
Aggiungi Commento
Conclusione
Elizabeth Kelly
Membro da: 22/10/2012
501 Reputazione
10 Guide realizzate
Clemson, Team 15-1, Benson Fall 2012 Membro di Clemson, Team 15-1, Benson Fall 2012
CLEM-BENSON-F12S15G1
4 Membri
10 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 17
Tutti i Tempi: 1,265
