Salta al contenuto principale
Panasonic HDC-TM15 Side Cover Replacement
Cosa ti serve
  1. Panasonic HDC-TM15 Side Cover Replacement, Side Cover: passo 1, immagine 1 di 1
    • Using the Phillips #00 Screwdriver, unscrew the five .5 mm Phillips #00 screws on the hand-strap side of the camcorder.
  2. Panasonic HDC-TM15 Side Cover Replacement: passo 2, immagine 1 di 1
    • Next, unscrew the six .5 mm Phillips #00 screws on the bottom of the camcorder.
  3. Panasonic HDC-TM15 Side Cover Replacement: passo 3, immagine 1 di 3 Panasonic HDC-TM15 Side Cover Replacement: passo 3, immagine 2 di 3 Panasonic HDC-TM15 Side Cover Replacement: passo 3, immagine 3 di 3
    • By putting your hand through the hand-strap, tug on the side cover until it comes off completely.
    • Once the old cover is completely detached, set it aside.
    • The inside of your camcorder should now be completely exposed, as seen in the photos.
  4. Panasonic HDC-TM15 Side Cover Replacement: passo 4, immagine 1 di 2 Panasonic HDC-TM15 Side Cover Replacement: passo 4, immagine 2 di 2
    • Line up the new side cover in the exact same place, ensuring that the screw holes match.
    • Re-screw the side cover into place.
  5. Panasonic HDC-TM15 Side Cover Replacement: passo 5, immagine 1 di 1
    • Gently tug on the hand-strap to ensure that the screws are tight and the side cover is secure.
    • When the side cover is securely fastened, you have completed the side cover replacement of your Panasonic HDC-TM15 camcorder.
Conclusione
Tricia Fallo
Membro da: 03/11/15
210 Reputazione
2 Guide realizzate
Marist, Team 1-4, Laflen Spring 2015 Membro di Marist, Team 1-4, Laflen Spring 2015
MARS-LAFLEN-S15S1G4
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 304
