Salta al contenuto principale
Panasonic HDC-TM15 Hand-Strap Replacement
Cosa ti serve
  1. Panasonic HDC-TM15 Hand-Strap Replacement, Hand-Strap: passo 1, immagine 1 di 1
    • Using the Phillips #00 Screwdriver, unscrew the five .5 mm Phillips #00 screws on the hand-strap side of the camcorder.
  2. Panasonic HDC-TM15 Hand-Strap Replacement: passo 2, immagine 1 di 1
    • Unscrew the six .5 mm Phillips #00 screws on the bottom of the camcorder.
  3. Panasonic HDC-TM15 Hand-Strap Replacement: passo 3, immagine 1 di 3 Panasonic HDC-TM15 Hand-Strap Replacement: passo 3, immagine 2 di 3 Panasonic HDC-TM15 Hand-Strap Replacement: passo 3, immagine 3 di 3
    • Once all eleven screws have been removed, put your hand through the hand-strap and tug on the side cover until it comes off completely.
    • The inside of your camcorder should now be completely exposed, as shown in the photos.
  4. Panasonic HDC-TM15 Hand-Strap Replacement: passo 4, immagine 1 di 3 Panasonic HDC-TM15 Hand-Strap Replacement: passo 4, immagine 2 di 3 Panasonic HDC-TM15 Hand-Strap Replacement: passo 4, immagine 3 di 3
    • For the remainder of the hand-strap replacement, you will only be working with the side cover of the camcorder.
    • Unscrew the two silver .5 mm Phillips #00 screws located in the bottom corners of the inside of the side cover. This will release the two silver plates that hold the hand-strap in place.
  5. Panasonic HDC-TM15 Hand-Strap Replacement: passo 5, immagine 1 di 2 Panasonic HDC-TM15 Hand-Strap Replacement: passo 5, immagine 2 di 2
    • Remove the two silver plates from the loops of the hand-strap.
  6. Panasonic HDC-TM15 Hand-Strap Replacement: passo 6, immagine 1 di 1
    • Pull the hand-strap through the holes of the side cover, until it is completely detached.
    • Set the old hand-strap aside.
  7. Panasonic HDC-TM15 Hand-Strap Replacement: passo 7, immagine 1 di 3 Panasonic HDC-TM15 Hand-Strap Replacement: passo 7, immagine 2 di 3 Panasonic HDC-TM15 Hand-Strap Replacement: passo 7, immagine 3 di 3
    • During these next replacement steps, the inside of the side cover should be facing you.
    • Taking your new hand-strap, first feed the smaller loop through the bottom right hole of the side cover.
  8. Panasonic HDC-TM15 Hand-Strap Replacement: passo 8, immagine 1 di 2 Panasonic HDC-TM15 Hand-Strap Replacement: passo 8, immagine 2 di 2
    • Feed the hooked end of the smaller silver plate through the first loop of the new hand-strap.
    • Slide the sliver plate into place, lining up the screw holes, and screw in tightly.
  9. Panasonic HDC-TM15 Hand-Strap Replacement: passo 9, immagine 1 di 2 Panasonic HDC-TM15 Hand-Strap Replacement: passo 9, immagine 2 di 2
    • Feed the larger loop through the hole in the opposite corner of the side cover.
  10. Panasonic HDC-TM15 Hand-Strap Replacement: passo 10, immagine 1 di 2 Panasonic HDC-TM15 Hand-Strap Replacement: passo 10, immagine 2 di 2
    • Feed the U-shaped silver plate through the second, larger loop of the new hand-strap in the opposite corner of the side cover.
    • Ensure the screw hole is lined up.
  11. Panasonic HDC-TM15 Hand-Strap Replacement: passo 11, immagine 1 di 1
    • Re-screw the two silver screws tightly back into the silver plates.
  12. Panasonic HDC-TM15 Hand-Strap Replacement: passo 12, immagine 1 di 1
    • Tug on the hand-strap to ensure it is securely in place.
    • If your new hand-strap feels secure, you can now re-attach the side cover to your camcorder.
  13. Panasonic HDC-TM15 Hand-Strap Replacement: passo 13, immagine 1 di 1
    • When the side cover is securely fastened, you have completed the hand-strap replacement of your Panasonic HDC-TM15 camcorder.
Conclusione
Tricia Fallo
Membro da: 03/11/15
210 Reputazione
2 Guide realizzate
Marist, Team 1-4, Laflen Spring 2015 Membro di Marist, Team 1-4, Laflen Spring 2015
MARS-LAFLEN-S15S1G4
3 Membri
6 Guide realizzate
Un commento
Any idea where the replacement strap can be purchased? Thank you
Suzi Finkenbine - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 8
Tutti i Tempi: 872
