Salta al contenuto principale
Panasonic HC‑VX870 Record Button Replacement
Cosa ti serve
  1. Panasonic HC‑VX870 Record Button Replacement, Side Cover: passo 1, immagine 1 di 3 Panasonic HC‑VX870 Record Button Replacement, Side Cover: passo 1, immagine 2 di 3 Panasonic HC‑VX870 Record Button Replacement, Side Cover: passo 1, immagine 3 di 3
    • Unscrew the J1 screws on the left side of the camcorder.
    • Unscrew the marked screws on the bottom of the camcorder.
    • Unscrew the marked screws on the back of the camcorder.
  2. Panasonic HC‑VX870 Record Button Replacement: passo 2, immagine 1 di 2 Panasonic HC‑VX870 Record Button Replacement: passo 2, immagine 2 di 2
    • Pull off the left side of the camcorder. You may have to use a little force but don't worry about breaking anything in the camcorder.
  3. Panasonic HC‑VX870 Record Button Replacement, Record Button Mechanism: passo 3, immagine 1 di 1
    • Unscrew the indicated screw.
  4. Panasonic HC‑VX870 Record Button Replacement: passo 4, immagine 1 di 1
    • Lift up on the little tab indicated in the picture and push away from the camera in order to remove the record button.
  5. Panasonic HC‑VX870 Record Button Replacement: passo 5, immagine 1 di 3 Panasonic HC‑VX870 Record Button Replacement: passo 5, immagine 2 di 3 Panasonic HC‑VX870 Record Button Replacement: passo 5, immagine 3 di 3
    • Take out the piece that that was held in place by the screw and separate the smaller piece from the larger piece.
Conclusione
Cal Poly, Team 13-6, Banghart Winter 2017 Membro di Cal Poly, Team 13-6, Banghart Winter 2017
CPSU-BANGHART-W17S13G6
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 424
