Salta al contenuto principale
Panasonic ES-RF31 Battery Replacement
Cosa ti serve
  1. Panasonic ES-RF31 Battery Replacement, Battery: passo 1, immagine 1 di 3 Panasonic ES-RF31 Battery Replacement, Battery: passo 1, immagine 2 di 3 Panasonic ES-RF31 Battery Replacement, Battery: passo 1, immagine 3 di 3
    • Loose the screw at the bottom part of the razor
  2. Panasonic ES-RF31 Battery Replacement, Removing the Backcover: passo 2, immagine 1 di 3 Panasonic ES-RF31 Battery Replacement, Removing the Backcover: passo 2, immagine 2 di 3 Panasonic ES-RF31 Battery Replacement, Removing the Backcover: passo 2, immagine 3 di 3
    • Slide the cover from top to bottom
  3. Panasonic ES-RF31 Battery Replacement, Removing the Batterycover: passo 3, immagine 1 di 2 Panasonic ES-RF31 Battery Replacement, Removing the Batterycover: passo 3, immagine 2 di 2
    • Loosen these eight screws
  4. Panasonic ES-RF31 Battery Replacement, Removing the Battery Cover: passo 4, immagine 1 di 2 Panasonic ES-RF31 Battery Replacement, Removing the Battery Cover: passo 4, immagine 2 di 2
    • Insert an opening tool into the gap
    • Gently remove the battery cover
  5. Panasonic ES-RF31 Battery Replacement, Removing the Battery: passo 5, immagine 1 di 2 Panasonic ES-RF31 Battery Replacement, Removing the Battery: passo 5, immagine 2 di 2
Conclusione
Altre 7 persone hanno completato questa guida.
Daniel
Membro da: 07/06/15
934 Reputazione
2 Guide realizzate
iFixit EU Team Membro di iFixit EU Team
Staff
44 Membri
1.110 Guide realizzate
4 Commenti
Thanks Daniel,
I followed your instructions and all went well. One thing to add: after re-assembly of the (loaded) battery my razor would not turn on. At first I thought of a bad contact, but it turned out that the razor needed a few minutes plugged into the power supply. After that it worked fine. I suspect, that the load-control hardware needs the external power to reset itself.
Cheers, Nils
Nils Kay - Replica
Hello Nils!
Thanks for the hint.
Glad to hear that your razor works again!
Greetings
Daniel - Replica
Daniel, thank you very much for instruction.
Unfortunetly, into shaver I found only 1 battery.
Because used 3.7 v element, I prepared 2 x 1.2 v batteries.
Виктор Богачёв - Replica
My razor was the Panasonic ES8103S and the disassembly process was similar. From the pictures above, the battery looks the same. My razor actually had a piece under the slide-off cover that was totally rusted so I will just buy a new one on Amazon for $50. For future reference, I would like to know where you get the replacement battery? There is no model number on the battery and I couldn’t find any info online.
David Paul - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 73
Tutti i Tempi: 6,044
