Salta al contenuto principale
Panasonic ER430K Battery Replacement
Cosa ti serve
  1. Panasonic ER430K Battery Replacement, Battery: passo 1, immagine 1 di 2 Panasonic ER430K Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Remove the battery cover by rotating it counter -clockwise and lifting it off.
    • Tilt the trimmer to the bottom, you will notice the battery housing.
  2. Panasonic ER430K Battery Replacement: passo 2, immagine 1 di 1
    • Insert the AA Battery according to the terminals on the Battery housing.
    • Note the '+' side in the the housing and the '-' side on the cover.
  3. Panasonic ER430K Battery Replacement: passo 3, immagine 1 di 1
    • Twist the battery cover housing in a clockwise direction to secure the the battery.
Conclusione
IUPUI, Team S22-G2, Bayer Fall 2017 Membro di IUPUI, Team S22-G2, Bayer Fall 2017
IUPUI-BAYER-F17S22G2
4 Membri
6 Guide realizzate
2Commenti sulla guida
Battery + side goes in first (when battery is inserted correctly, the - side will be facing you).
Marc2 Salvisberg - Replica
i prided the negative tab on the cover up to make contact. the trimmer roared to life again!
Dean Jarvis - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 53
Tutti i Tempi: 5,151
