Salta al contenuto principale
Panasonic ER-GN30-K Motor Shaft Replacement
Cosa ti serve
  1. Panasonic ER-GN30-K Motor Shaft Replacement, Motor Shaft: passo 1, immagine 1 di 1
    • Remove the dark transparent cap by gently pulling on it.
  2. Panasonic ER-GN30-K Motor Shaft Replacement: passo 2, immagine 1 di 1
    • Remove the back battery cap from the device by twisting it to the unlock position and pulling.
  3. Panasonic ER-GN30-K Motor Shaft Replacement: passo 3, immagine 1 di 1
    • Remove the black trimmer cap from the top of the device by gently pulling it.
  4. Panasonic ER-GN30-K Motor Shaft Replacement: passo 4, immagine 1 di 1
    • The motor shaft should be sticking out from the top of the device.
    • Use the metal prying tool to pry apart the silver plastic case .
    • Pull each side of the plastic case off.
    This photo almost made me break my trimmer. You don’t stick your pry tool here but underneath the bottom.
    [deleted] - Replica
  5. Panasonic ER-GN30-K Motor Shaft Replacement: passo 5, immagine 1 di 1
    • Unscrew one 20mm Phillips #00 screw.
  6. Panasonic ER-GN30-K Motor Shaft Replacement: passo 6, immagine 1 di 1
    • Remove the rubber stopper from the top of the motor shaft by gently pulling it off.
  7. Panasonic ER-GN30-K Motor Shaft Replacement: passo 7, immagine 1 di 2 Panasonic ER-GN30-K Motor Shaft Replacement: passo 7, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Use a pair of tweezers to remove the plastic cover of the motor shaft by pulling it away from the motor.
    Hi, when trying to reassemble the trimmer I have a problem with the switch. I do not understand how the mechanical connection between the final switch and the inner one is done. I am wondering if I lost a part…
    Chris - Replica
Conclusione
USF Tampa, Team 15-3, Blackwell Fall 2015 Membro di USF Tampa, Team 15-3, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G3
4 Membri
10 Guide realizzate
2 Commenti
Thank you, small parts where switch is could be shown as well. Would be very helpful.
Advise for putting things back together: remove plastic switch cover and put back only after full reassembly
Aurimas Miko - Replica
Dear Alejandro,
thank You for your instruction, my question is where this motor shaft part is available? I can’t find it anywhere on the net. Thanks if you can help. Bence Fazekas
fazebence - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 21
Tutti i Tempi: 1,693
