Salta al contenuto principale
Panasonic ER-GN30-K Blade Replacement
  1. Panasonic ER-GN30-K Blade Replacement, Blade: passo 1, immagine 1 di 1
    • Remove the dark transparent cap by gently pulling on it.
  2. Panasonic ER-GN30-K Blade Replacement: passo 2, immagine 1 di 1
    • Remove the black trimmer cap from the top of the device by gently pulling it.
  3. Panasonic ER-GN30-K Blade Replacement: passo 3, immagine 1 di 1
    • Remove the blade from the cap by gently pulling it from the cap.
    • Even if the blade is dull or broken, it will still be sharp enough to cut skin, so be careful while you remove it.
Conclusione
Altre 5 persone hanno completato questa guida.
USF Tampa, Team 15-3, Blackwell Fall 2015 Membro di USF Tampa, Team 15-3, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G3
4 Membri
10 Guide realizzate
6 Commenti
Looked everywhere...anybody know where to get replacement blades for the Panasonic ER-GN30 nose & ear trimmer?
R Holmes - Replica
Did you ever find a replacement blade?
PCARRINGTON - Replica
I called Panasonic's support number, and supposedly the inner blade at least, is priced from around $14 to $20, from various places. Considering major resellers have the whole trimmer for around $12, it would not make sense to get just a blade. Amazon has open-box wearhouse deals now, where the trimmers can be had for under $5.00. I may get one of these myself :)
Jim Locke - Replica
Hola yo acabo de comprar las cuchillas a 7€ , les dejo el enlace https://juanluismartel.com ademas me repararon una camara Panasonic Lumix, Gracias.
usblsb - Replica
still looking
jorgensen - Replica
Why would a nose hair trimmer need a replacement blade? And this particularly blade is more expensive then the trimmer itself.
Caba Alex - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 23
Ultimi 30 Giorni: 58
Tutti i Tempi: 13,545
