Salta al contenuto principale
Panasonic DMP-BD89 Wifi Board Replacement
Cosa ti serve
  1. Panasonic DMP-BD89 Wifi Board Replacement, Disk Tray Cover: passo 1, immagine 1 di 2 Panasonic DMP-BD89 Wifi Board Replacement, Disk Tray Cover: passo 1, immagine 2 di 2
    • First, before powering off, press the eject button to open the tray.
  2. Panasonic DMP-BD89 Wifi Board Replacement: passo 2, immagine 1 di 3 Panasonic DMP-BD89 Wifi Board Replacement: passo 2, immagine 2 di 3 Panasonic DMP-BD89 Wifi Board Replacement: passo 2, immagine 3 di 3
    • Remove the front cover of the tray.
    • Do so by gently pushing it out, away from the player, ensuring the pictured tabs clear the tray.
    • Then slide it vertically up and away.
  3. Panasonic DMP-BD89 Wifi Board Replacement: passo 3, immagine 1 di 2 Panasonic DMP-BD89 Wifi Board Replacement: passo 3, immagine 2 di 2
    • Press eject button to close the tray.
    • Make sure to unpower and unplug device before continue work on other fixes.
  4. Panasonic DMP-BD89 Wifi Board Replacement, Exterior Cover: passo 4, immagine 1 di 2 Panasonic DMP-BD89 Wifi Board Replacement, Exterior Cover: passo 4, immagine 2 di 2
    • Using a Phillips #1 screwdriver, unscrew the back three screws.
  5. Panasonic DMP-BD89 Wifi Board Replacement: passo 5, immagine 1 di 1
    • Slide the top panel horizontally to remove it.
  6. Panasonic DMP-BD89 Wifi Board Replacement: passo 6, immagine 1 di 3 Panasonic DMP-BD89 Wifi Board Replacement: passo 6, immagine 2 di 3 Panasonic DMP-BD89 Wifi Board Replacement: passo 6, immagine 3 di 3
    • Locate 6 tabs across the device.
    • 2 are on the bottom, 1 is on the left and right, and 2 are are on the inside.
  7. Panasonic DMP-BD89 Wifi Board Replacement: passo 7, immagine 1 di 1
    • Pop the 6 markers out.
    • Then take off the cover.
  8. Panasonic DMP-BD89 Wifi Board Replacement, Wifi Board: passo 8, immagine 1 di 2 Panasonic DMP-BD89 Wifi Board Replacement, Wifi Board: passo 8, immagine 2 di 2
    • Locate reddish brown cable. Detach from green circuit board by pulling upward.
  9. Panasonic DMP-BD89 Wifi Board Replacement: passo 9, immagine 1 di 1
    • Using tweezer, compress the white knob holding the wifi module board in place.
  10. Panasonic DMP-BD89 Wifi Board Replacement: passo 10, immagine 1 di 2 Panasonic DMP-BD89 Wifi Board Replacement: passo 10, immagine 2 di 2
    • Pull the module board straight up, removing completely. The second photo is how your device should look with the WiFi board removed.
Conclusione
Mohan Saxena
Membro da: 10/17/17
133 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 374
