Introduzione
The Operations Unit is a panel of top of the camera that contains the mode dial, power switch, shutter button, and video-record button. If any of these buttons are missing, jammed, or no longer working, you can use this guide to learn how to replace the unit. Before you begin, make sure that the battery and SD card have been removed.
Cosa ti serve
Using your screwdriver, unscrew the two 5.0 mm Philips screws to the right of the LCD screen.
Using a Torx driver, unscrew the two 5mm Phillipd screws on the motherboard
Unscrew one 10mm Phillips screw to the right and underneath the viewfinder.
Altre 4 persone hanno completato questa guida.
Un commento
Alberto,
Great instructions! Saved me $165 (compared to camera repair shop).
