Salta al contenuto principale
Panasonic DMC-FZ70 Back Panel Replacement
Cosa ti serve
  1. Panasonic DMC-FZ70 Back Panel Replacement, Back Panel: passo 1, immagine 1 di 2 Panasonic DMC-FZ70 Back Panel Replacement, Back Panel: passo 1, immagine 2 di 2
    • All screws should be removed using a Phillips #0 screwdriver.
    • Using your screwdriver, unscrew the two 5.0 mm Philips screws to the right of the LCD screen.
  2. Panasonic DMC-FZ70 Back Panel Replacement: passo 2, immagine 1 di 2 Panasonic DMC-FZ70 Back Panel Replacement: passo 2, immagine 2 di 2
    • Flip the camera over to the left side of the screen and unscrew the 5mm Phillips screw found there.
  3. Panasonic DMC-FZ70 Back Panel Replacement: passo 3, immagine 1 di 2 Panasonic DMC-FZ70 Back Panel Replacement: passo 3, immagine 2 di 2
    • Turn the camera upside down and unscrew the three 5mm screws found on the bottom.
  4. Panasonic DMC-FZ70 Back Panel Replacement: passo 4, immagine 1 di 2 Panasonic DMC-FZ70 Back Panel Replacement: passo 4, immagine 2 di 2
    • On the top of the camera locate the two rails with a thin sheet of metal on the floor between them.
    • With a metal spudger, lift this sheet and push it out of the rail device to detach it from the camera.
  5. Panasonic DMC-FZ70 Back Panel Replacement: passo 5, immagine 1 di 1
    • Proceed to remove the four 5mm Phillips screws that you just uncovered.
  6. Panasonic DMC-FZ70 Back Panel Replacement: passo 6, immagine 1 di 1
    • Slowly pull on both side of the camera, until both halves begin to separate from each other.
    • Do not pull too hard, as both halves are held together with ZIF connector cables.
  7. Panasonic DMC-FZ70 Back Panel Replacement: passo 7, immagine 1 di 3 Panasonic DMC-FZ70 Back Panel Replacement: passo 7, immagine 2 di 3 Panasonic DMC-FZ70 Back Panel Replacement: passo 7, immagine 3 di 3
    • Using a plastic opening tool, carefully flip up the small black levers that attach the ribbon cables to the ZIF connectors on the motherboard.
    • Carefully pull the ribbon cables out of the slot once they have been released.
    • Only the two indicated connectors need to be removed to separate the two halves of the camera.
Conclusione
Cal Poly, Team 21-3, Maness Winter 2017 Membro di Cal Poly, Team 21-3, Maness Winter 2017
CPSU-MANESS-W17S21G3
6 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 17
Tutti i Tempi: 673
