Salta al contenuto principale
Panasonic DECT 6.0 Button Replacement
Cosa ti serve
  1. Panasonic DECT  6.0 Button Replacement, Jammed/Broken Buttons: passo 1, immagine 1 di 3 Panasonic DECT  6.0 Button Replacement, Jammed/Broken Buttons: passo 1, immagine 2 di 3 Panasonic DECT  6.0 Button Replacement, Jammed/Broken Buttons: passo 1, immagine 3 di 3
    • Remove the battery cover by pushing the tab upwards and sliding it off.
    • Pull out the battery/energy source from its slot.
    • Keep all pieces in a safe and orderly manner for ease of reassembly.
  2. Panasonic DECT  6.0 Button Replacement: passo 2, immagine 1 di 3 Panasonic DECT  6.0 Button Replacement: passo 2, immagine 2 di 3 Panasonic DECT  6.0 Button Replacement: passo 2, immagine 3 di 3
    • Unscrew the screws you see on the inside of the casing using an appropriate screwdriver from the JIS Driver Set.
    • Carefully pry each side open with the iFixit Opening tool.
    • Detach the back of the phone case.
  3. Panasonic DECT  6.0 Button Replacement: passo 3, immagine 1 di 3 Panasonic DECT  6.0 Button Replacement: passo 3, immagine 2 di 3 Panasonic DECT  6.0 Button Replacement: passo 3, immagine 3 di 3
    • Unscrew the screws to remove the motherboard using an appropriate screwdriver from the JIS Driver Set.
    • Potential for device damage
  4. Panasonic DECT  6.0 Button Replacement: passo 4, immagine 1 di 3 Panasonic DECT  6.0 Button Replacement: passo 4, immagine 2 di 3 Panasonic DECT  6.0 Button Replacement: passo 4, immagine 3 di 3
    • Carefully pull off the circuitry and cords from the front half of the phone and set them aside.
    • Bring the buttons to the front.
  5. Panasonic DECT  6.0 Button Replacement: passo 5, immagine 1 di 2 Panasonic DECT  6.0 Button Replacement: passo 5, immagine 2 di 2
    • Pull gently to separate the button pad from the phone cover.
    • Identify the broken/jammed button you were having issues with.
    • Replace or return the button to its function.
Conclusione
Jacob
Membro da: 05/31/16
131 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 10
Tutti i Tempi: 536
