Salta al contenuto principale
Panasonic D-snap SV-AV50 Screen Replacement
Cosa ti serve
  1. Panasonic D-snap SV-AV50 Screen Replacement, Screen: passo 1, immagine 1 di 1
    • Open and rotate the screen, then remove the screw(3.5mm Philips) indicated with a screwdriver.
    • Then, rotate the screen 180 degrees and remove the screw on the opposite side.
  2. Panasonic D-snap SV-AV50 Screen Replacement: passo 2, immagine 1 di 1
    • Remove the screw(2.6mm Philips) indicated on the top of the screen with the screwdriver. Then remove the corresponding screw on the bottom of the screen.
  3. Panasonic D-snap SV-AV50 Screen Replacement: passo 3, immagine 1 di 1
    • Pull the backing away from the screen as shown in the photo.
  4. Panasonic D-snap SV-AV50 Screen Replacement: passo 4, immagine 1 di 1
    • Unplug the black connector between the camera and the screen by pulling down.
    • For increased ease, use tweezers or forceps, as seen in the picture
  5. Panasonic D-snap SV-AV50 Screen Replacement: passo 5, immagine 1 di 1
    • Pull the screen away from the camera the same way that you removed the screen backing.
  6. Panasonic D-snap SV-AV50 Screen Replacement: passo 6, immagine 1 di 1
    • Use the screwdriver to remove the screw(2.46mm Philips) indicated.
  7. Panasonic D-snap SV-AV50 Screen Replacement: passo 7, immagine 1 di 1
    • Pull upwards on the screen border to remove it from the actual screen.
Conclusione
Zoe Hinck
Membro da: 04/12/12
29 Reputazione
4 Guide realizzate
Cal Poly, Team 6-19, Amido Spring 2012 Membro di Cal Poly, Team 6-19, Amido Spring 2012
CPSU-AMIDO-S12S6G19
3 Membri
12 Guide realizzate
Un commento
I need the LCD screen, can you helpme?
leon - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 12
Tutti i Tempi: 1,072
