Introduzione
Be sure to remove the battery and SD card before opening the camera to get to the motherboard or flash. The motherboard must be removed to access the flash component.
Parti
Nessuna parte richiesta.
  1. Slide the bottom panel in the direction of the arrow on the panel.
    • Slide the bottom panel in the direction of the arrow on the panel.
  2. Pull/lift open the battery cover in the direction directly away from the camera.
    • Pull/lift open the battery cover in the direction directly away from the camera.
  3. Push the small gray plastic tab away from the battery in order to release the battery.
    • Push the small gray plastic tab away from the battery in order to release the battery.
  4. Pull the battery out of the camera.
    • Pull the battery out of the camera.
  5. Slide the bottom panel in the direction of the arrow on the panel.
  6. Pull/lift open the battery cover in the direction directly away from the camera.
  7. Push down on the SD card next to the battery in order to release the SD card.
    • Push down on the SD card next to the battery in order to release the SD card.
    • Pull the SD memory card out of the camera in the same way that you would pull out the battery.
  8. Spedizione gratuita per tutti gli ordini superiori a 100,00 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
    Mai riparato qualcosa? Questo è Genio.
    Condividi la tua storia di riparazione con #ImAGenius
    Siamo tutti Geni
  9. Slide the bottom panel in the direction of the arrow on the panel.
  10. Pull/lift open the battery cover in the direction directly away from the camera.
  11. Remove the two screws (2.2mm Philips) indicated.
    • Remove the two screws (2.2mm Philips) indicated.
  12. Remove the piece of the frame that covers the camera's function buttons by pulling upwards from the end, as shown in the picture.
    • Remove the piece of the frame that covers the camera's function buttons by pulling upwards from the end, as shown in the picture.
    • It may feel like you are breaking the camera, since the frame makes a snapping sound as you remove it. However, as long as you are careful to remove the frames individually as shown, the frames will probably not break.
  13. Turn the camera and remove the frame from the opposite side of the camera by pulling from either the top or the bottom in an outwards direction.
    • Turn the camera and remove the frame from the opposite side of the camera by pulling from either the top or the bottom in an outwards direction.
    • As in the previous step, it may seem like you are breaking the camera, because the frame makes snapping noises, as you pull it apart.This is to be expected, and will not harm the camera.
  14. Remove the two screws (4.08mm" Philips) that are indicated in the picture.
    • Remove the two screws (4.08mm" Philips) that are indicated in the picture.
    • Flip the camera 180 degrees and remove the corresponding screws on the opposite side of the camera
  15. Remove the backing of the camera from the side opposite the screen
    • Remove the backing of the camera from the side opposite the screen
    • To make it easier for yourself, pull the screen outwards from the bottom of the camera, near the battery cover.
  16. Remove the small cover from near the top of the motherboard, using tweezers or forceps, as in the picture.
    • Remove the small cover from near the top of the motherboard, using tweezers or forceps, as in the picture.
  17. Unscrew the two screws (5.18mm Philips) indicated by the picture.
    • Unscrew the two screws (5.18mm Philips) indicated by the picture.
  18. Carefully remove the motherboard from the camera by grasping the sides and pulling upwards and then outwards.
    • Carefully remove the motherboard from the camera by grasping the sides and pulling upwards and then outwards.
  19. Remove the top piece of the casing from the camera, as shown in the picture.
    • Remove the top piece of the casing from the camera, as shown in the picture.
  20. Carefully remove the top most piece of the upper frame as indicated in the picture.
    • Carefully remove the top most piece of the upper frame as indicated in the picture.
    • You may need to manipulate the pieces of the frame until they disconnect from one another.
    • The two side pieces should "fall" off after this piece is removed.
  21. This is what the flash looks like.
    • This is what the flash looks like.
Conclusione
Bryan
Membro da: 12/04/2012
1 Reputazione
2 Guide realizzate
Cal Poly, Team 6-19, Amido Spring 2012 Membro di Cal Poly, Team 6-19, Amido Spring 2012
CPSU-AMIDO-S12S6G19
3 Membri
6 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 474
