Salta al contenuto principale
Panasonic CF-31 Toughbook Keyboard Replacement
Cosa ti serve
  1. Panasonic CF-31 Toughbook  Keyboard  Replacement, Keyboard: passo 1, immagine 1 di 3 Panasonic CF-31 Toughbook  Keyboard  Replacement, Keyboard: passo 1, immagine 2 di 3 Panasonic CF-31 Toughbook  Keyboard  Replacement, Keyboard: passo 1, immagine 3 di 3
    • Open the battery compartment by pulling the tab forward and then down.
    • Open the compartment door by pushing down.
    • Use the plastic tab to pull the battery out of the compartment.
  2. Panasonic CF-31 Toughbook  Keyboard  Replacement: passo 2, immagine 1 di 2 Panasonic CF-31 Toughbook  Keyboard  Replacement: passo 2, immagine 2 di 2
    • Use a Phillips #2 screwdriver to remove the three screws from the bezel.
    • Use a nylon spudger to remove the bezel.
  3. Panasonic CF-31 Toughbook  Keyboard  Replacement: passo 3, immagine 1 di 2 Panasonic CF-31 Toughbook  Keyboard  Replacement: passo 3, immagine 2 di 2
    • Use a nylon spudger to lift each corner of the keyboard.
    • Use your hands and gently pull back to remove the keyboard.
  4. Panasonic CF-31 Toughbook  Keyboard  Replacement: passo 4, immagine 1 di 2 Panasonic CF-31 Toughbook  Keyboard  Replacement: passo 4, immagine 2 di 2
    • Use a Phillips # 2 screwdriver to remove the four screws securing the keyboard shield.
    • Remove the keyboard shield.
  5. Panasonic CF-31 Toughbook  Keyboard  Replacement: passo 5, immagine 1 di 1
    • Remove the top left ribbon cable using a nylon spudger to pull the top and bottom tabs right.
  6. Panasonic CF-31 Toughbook  Keyboard  Replacement: passo 6, immagine 1 di 1
    • Remove the top right ribbon cable using a nylon spudger and push the top and bottom tabs left.
  7. Panasonic CF-31 Toughbook  Keyboard  Replacement: passo 7, immagine 1 di 2 Panasonic CF-31 Toughbook  Keyboard  Replacement: passo 7, immagine 2 di 2
    • Remove the bottom left ribbon cable using a nylon spudger and push the top and bottom tabs right.
Conclusione
To reassemble the Panasonic CF-31 Toughbook Laptop, follow these instructions in reverse order.
Richard Gill
Membro da: 01/16/19
145 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 45
Tutti i Tempi: 2,408
