Salta al contenuto principale
Palm v Outer Case Replacement
Cosa ti serve
  1. Palm v Outer Case Replacement, Outer Case: passo 1, immagine 1 di 1
    • Lay device face down on surface.
  2. Palm v Outer Case Replacement: passo 2, immagine 1 di 2 Palm v Outer Case Replacement: passo 2, immagine 2 di 2
    • Heat the left and top edges with hairdryer for one minute.
    • Move hairdryer back and forth to evenly heat up surface.
    • Caution: directly heating the screen can melt or distort the screen.
  3. Palm v Outer Case Replacement: passo 3, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use tweezers to hold Palm right side down on it's side.
    • Use a plastic opening tool to pry open front and back casing.
    • If you are unable to open you may need to heat with hairdryer for longer.
    • Be sure not to touch case directly with fingers, it will be hot!
  4. Palm v Outer Case Replacement: passo 4, immagine 1 di 1
    • Leave plastic opening tools in between front and back casing.
    • Rotate Palm and repeat steps 2 and 3 for right and back edges.
  5. Palm v Outer Case Replacement: passo 5, immagine 1 di 3 Palm v Outer Case Replacement: passo 5, immagine 2 di 3 Palm v Outer Case Replacement: passo 5, immagine 3 di 3
    • Now pry open front and back casing with plastic opening tools.
    • Separate front and back casing completely.
    • Power button will fall off once front and back casing have been removed. Be sure not to lose it.
Linea Traguardo
Cal Poly, Team 13-25, Maness Winter 2010 Membro di Cal Poly, Team 13-25, Maness Winter 2010
CPSU-MANESS-W10S13G25
4 Membri
4 Guide realizzate
Un commento
So...This given by my grandmother and it is out of battery. Unluckily, it won't charge, because the %#*@ old battery had gone kaput. I had a hard time finding one that might be suitable, and turnout that I need to insert it into the device and connect it to the circuit board. I have some solid soldering skills, but without a heat gun, the andonized cover won't come off. And what's more, I jammed a pencil tip into the "reset" hole when trying to reset the device. Thinking the big opening was a kind of cover-releasing button...I was just having a whole lot of trouble and thinking too much. !&&*.
Xavier Jiang - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 8
Tutti i Tempi: 1,619
